Ballistics Momentum problem
  • Thread starter ZzZerozZ
ZzZerozZ
In a ballistics test, a 25.0g bullet traveling horizontally at 1100m/s goes through a 40.0cm -thick 250kg stationary target and emerges with a speed of 900m/s . The target is free to slide on a smooth horizontal surface.
the 1st question of this problem ask: How long is the bullet in the target?
I simply do:
40.0cm=0.4m ; 0.4m/(900m/s)=4.4*10^-4
The answer shows 4.0*10^-4
Did I make a mistake or it is just a rounding problem?
Answers and Replies
tiny-tim
25,836
255
Welcome to PF!
Hi ZzZerozZ! Welcome to PF! :smile:
i] in your distance/speed, you've used the width of the block as the distance, but the block is moving, so the distance is longer
ii] your speed is the final speed, so it's too small :redface:
nilic1
39
I simply do:
Using s = (u+v)/2 *t the answer is 4 *10^-4. s= distance, u = inital vel, v= final vel.
Suggested for: Ballistics Momentum problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
