Homework Help: Balloon in a vacuum
  1. Mar 20, 2017 #1
    Balloon in vacuum, radius R0 = 5,0 cm, surface tension σ = 25 N/m.
    a/ the pressure in the balloon p in,0 by radius R0………. pin,0 = ?
    b/ relation to the pressure inside the balloon pin, depending on its radius R…?
    c/relation to the pressure inside the balloon pin , depending on the pressure outside the balloon pout and on its radius R, surface tension is σ…….?
    2. Relevant equations
    a/ pin,0=4σ/R0 = 4.25/0,05 = 2kPa
    b/ pin = 4σ/R
    c/ pin = pout + 4σ/R
    3. The attempt at a solution
  3. Mar 20, 2017 #2
    mfb
    2017 Award
    Staff: Mentor
    Looks right.
  4. Mar 20, 2017 #3
    in B/ I have to use pressure p in 0.....
    p in = 4σ/R .....R = R0 + ΔR = R0 + ( R-R0)....p in = 4σ/R0 + ( R-R0)
  5. Mar 20, 2017 #4
    mfb
    2017 Award
    Staff: Mentor
    If you add proper brackets to the denominators, you get the same result as in post 1.
  6. Mar 20, 2017 #5
    so:?
    p in = p in 0 + 4σ/ ( R- R0)
  7. Mar 20, 2017 #6
    mfb
    2017 Award
    Staff: Mentor
    That looks wrong, no matter how I interpret the notation, and I don't see how you got it. In particular, it is undefined for the easiest case of R=R0.
    Why do you want to change a correct answer?
  8. Mar 20, 2017 #7
    Because I have to find dependence p in on p in 0 : Find the equation for the pressure p in inside the balloon, depending on the radius R, where
    at radius R 0 is pressure p in 0
  9. Mar 20, 2017 #8
    mfb
    2017 Award
    Staff: Mentor
    That's not what you write in post 1.
  10. Mar 20, 2017 #9
    Yes, it's true, I did not read the assignment to the end :-( I am sorrry.....
  11. Mar 20, 2017 #10
    haruspex
    Your notation is hard to interpret, but I think you are saying:
    With zero external pressure, the radius is R0 and the internal pressure is pin0.
    With some unknown external pressure the radius is R; what is the internal pressure, pin, now?
    If that is right, write out the equation for each of the two circumstances. Please use subscripts, as I have, to make the notation clearer. Use the X2 button above the text entry box.
  12. Mar 21, 2017 #11
    b/ Find the equation for the pressure p in inside the balloon, depending on the radius R, where
  13. Mar 21, 2017 #12
    haruspex
    Yes, that agrees with my interpretation. So what two equations can you write, one for the zero external pressure case and one for the general case?
  14. Mar 21, 2017 #13
    in vacuum : ......pin = 4σ/R.....for R0 .....pin0 = 4σ/R0
    p in = 4σ/R .....R = R0 + ΔR = R0 + ( R-R0)....p in = 4σ/ (R0 + ( R-R0))
    - But here now I can not express pin0
    for the general case: pin = pout + 4σ/R
  15. Mar 21, 2017 #14
    haruspex
    It's all the same balloon and contents. What does not vary as the external pressure changes?
  16. Mar 21, 2017 #15
    surface tension?
  17. Mar 21, 2017 #16
    haruspex
    What else?
  18. Mar 21, 2017 #17
    the amount of air in the balloon ?
  19. Mar 21, 2017 #18
    haruspex
    Right. What law can you use?
  20. Mar 21, 2017 #19
    p1V1 =p2V2........?
  21. Mar 21, 2017 #20
    haruspex
    Yes. (You can assume the temperature is constant.)
  22. Mar 21, 2017 #21
    pin0V0=pinV
    pin = pin0*V0 / V = pin0 * (V0 / V ) = pin0 * (R03 / R3 ) .........?
  23. Mar 21, 2017 #22
    haruspex
    Yes.
  24. Mar 21, 2017 #23
    super..thanks very much :-)
  25. Mar 21, 2017 #24
    haruspex
    Ok, but what is your answer to the question, i.e. as an equation for pin in terms of pout, R and σ?
  26. Mar 21, 2017 #25
    oh yes.........pin = pout + 4σ/R...?
Have something to add?
Draft saved Draft deleted
