Balloon Pipe Expt: Reviews Needed for Thought Experiment
In summary, the conversation discussed a thought experiment involving an "inflatable pipe" operating in vacuum and how it would behave under fluid flow. The purpose was to study the pressure and curvature of the pipe, with the prediction that at high velocities, the pipe would cave in at the linear ends and inflate at the curvature. The conversation also mentioned the idea of studying flexible air or hydraulic lines and ended with a statement about politeness and forum rules preventing further observations.
vin300
603
Just made up a thought experiment. Looking for reviews. As follows: Assuming an "inflatable pipe" operating in vacuum to neglect ext. Influence, fluid flows through the pipe such that supports are only at the two rigid end connectors.The pipe will sag during operation due to fluid self weight. The purpose is to create natural curvature and study pressure at various points such that negative pressure will "deflate" the pipe and vice versa. At high velocities the prediction I'm making is that at the linear ends, pipe caves in, trying to block the flow while excess positive pressure at the curvature tends to inflate at that point until the pipe tensional reaction pushes through the deflated ends thus making a vibrating fluid line with cyclic flow and pressure at every point.
(1) Study any flexible air or hydraulic line as contained pressure varies .
(2) Politeness and forum rules prevent me from giving any further observations .
Likes Chestermiller
1. How does the balloon pipe experiment work?
The balloon pipe experiment involves filling a pipe with a small amount of water and attaching a balloon to one end. As the water is heated, it turns into steam and expands, causing the balloon to inflate. This demonstrates the concept of thermal expansion.
2. What materials are needed for the balloon pipe experiment?
To conduct the balloon pipe experiment, you will need a pipe, a balloon, water, and a heat source such as a Bunsen burner or hot plate. You may also need a thermometer to measure the temperature of the water.
3. What is the purpose of the balloon pipe experiment?
The purpose of the balloon pipe experiment is to demonstrate the concept of thermal expansion. As the water is heated, it expands and takes up more space, causing the balloon to inflate. This can also be used to explain real-world phenomena such as the expansion of materials in bridges and buildings due to changes in temperature.
4. Can the balloon pipe experiment be modified for different age groups?
Yes, the balloon pipe experiment can be modified for different age groups by adjusting the level of complexity and explanation. For younger children, the focus can be on the visual demonstration of thermal expansion, while for older students, the experiment can be used to explain the scientific principles behind this phenomenon.
5. Are there any safety precautions to consider when conducting the balloon pipe experiment?
Yes, there are a few safety precautions to consider when conducting the balloon pipe experiment. Make sure to use caution when handling hot water and heat sources, and always have adult supervision. It is also important to use heat-resistant materials and to not overheat the water, as this could cause the balloon to burst.
14K
9K
  • Mechanics
  • Mechanical Engineering
