1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Banked Roadway Physics
  1. Jun 13, 2015 #1
    A civil engineer wishes to redesign the curved roadway in Interactive Example 5.7 in such a way that a car will not have to rely on friction to round the curve without skidding. In other words, a car moving at the desig- nated speed can negotiate the curve even when the road is covered with ice. Such a curve is usually banked, meaning that the roadway is tilted toward the inside of the curve. Suppose the designated speed for the curve is to be 13.4 m/s (30.0 mi/h) and the radius of the curve is 35.0 m. At what angle should the curve be banked?
    2. Relevant equations
    nsin(theta) = mv2 /r
    ncos(theta) = mg
    tan(theta) = v2/rg
    3. The attempt at a solution
    I had thought that looking at horizontal movement on the slope you would use mgsin(theta) = mv2/r, so that the force is parallel with the slope. Why are we not doing this? Thanks.
  3. Jun 13, 2015 #2
    Wouldn't it depend on how you measured r?
  4. Jun 13, 2015 #3
    You can assume r is measured to the COM of the car.
    For problems like this it is often easier to define an axis parallel to the slope and work that way. Then you can ignore the normal force as it makes no contribution to what you are interested in; what theta is when all forces parallel to the slope sum to zero.
    With that said, the force due to the centripetal acceleration is not parallel to the slope, it's horizontal. so your expression mgsin(theta) = mv2/r will not give the correct answer. Those two force vectors are not collinear.
  5. Jun 14, 2015 #4
    Okay, I didn't realize that centripetal acceleration wasn't parallel with the slope, but now that I think about it, that makes complete sense. Thanks!
  6. Jun 15, 2015 #5
    Have a look at the sheet i have attached, note that its an intuitive solution.
  7. Jun 16, 2015 #6
    You should clarify that that is using the centrifugal force view, not an inertial frame.
Have something to add?
Draft saved Draft deleted
Similar Threads - Banked Roadway Physics Date
Car on a bank problem need help ?!! Dec 13, 2017
Car on a banked roadway Oct 28, 2013
A banked roadway with static friction Oct 22, 2011
The banked roadway Apr 5, 2010
Circular Motion - Roadway Bank Angle Oct 2, 2008
