Barium chromate
  • Thread starter semc
Hi guys today in the lab i did reaction of barium chromate with hydrochloric acid and when i add HCL to barium chromate i got a reddish orange solution but when i add sulphuric acid i got a colorless solution with yellow ppt. Why is this so? Shouldn't both give me the same result since they are both acid?
Answers and Replies
Borek
Mentor
28,827
3,344
Consult solubility table.
methods
Alright i googled it and found out that sulfur oxide is insoluble in barium so that is the reason why yellow ppt is formed and not a red solution?Well in that case why is it that when i add nitric acid to barium chromate there is no change in color? the solubility table says NO is soluble in anything.
Borek
Mentor
28,827
3,344
You don't deal with sulfur oxide nor nictric oxide, you are so wrong I have even no idea where to start the help... Are you sure NO didn't stand for no, as opposed to YES?
Do you know what a salt is? Have you heard about insoluble salts? Do you know why salts of weak acids dissolve in strong acids? Have you heard about LeChatelier's principle? Dissociation?
methods
actually i was trying to say (SO4)2- haha. Erm the NO is the NO in HNO. Yeap salt is the product formed when acid and base react ya? insoluble salt is a salt that does not dissolve in the solvent? Nope no idea why it dissolve.Yeah LeChatelier's principle. Acid dissocaiation?
Borek
Mentor
28,827
3,344
Put all indices and charges on the ions you are writing about, and call them properly. We need a common language. As of now we are wasting time because you speak alkhymystry instead of chemistry. No such thing as NO of HNO.
What ions are present in the solution?
Weak acid dissociation combined with LeChatelier's principle - what happens when weak acid is put into low pH solution?
methods
Weak acid in low pH? No dissociation? Aint HNO a strong acid?
Borek
Mentor
28,827
3,344
No such thing as HNO and we are talking about the problem you have posted at the very beginning, so don't get distracted.
I assume you mean that weak acids are not dissociated in low pH. That's correct enough for the problem. What ions are present in the solution?
Ops sorry i was referring to the test with nitric acid.
Hmm ions... Ba2+, (SO4)2- and CrO4?
Borek
Mentor
28,827
3,344
Stop ignoring charges. CrO4 is not an ion.
We are getting closer. Consult solubility table.
Dude i am not ignoring charges i just dont know what the charge is haha my chem is not that good man. (SO4)2- is not soluble in Ba2+ so that is the reason for the ppt?
Borek
Mentor
28,827
3,344
CrO42-, anion of a relatively weak acid H2CrO4. Do you know why chromates are soluble in strong acids? Hint: we have already discussed it partially, what you wrote in #7 is the most important reason behind.
Geez, alkhymystry again.
Barium sulfate is not soluble in water - that means, when you have both Ba2+ and SO42- in water, sulfate will preicipitate.
methods
Well i tried but i just cant make them look like chemistry..... alright i see the reason now but one more question. Why nothing happen when i add nitric acid to barium chromate?
Borek
Mentor
28,827
3,344
I am not referring to (SO4)2- - while this is not a standard way of writing formulas, it is clear what you mean. You may try SO4-2 or SO4-- in future, these are used quite often. However, when you write about dissolving SO42- in Ba2+ it doesn't make sense.
Nitric acid should dissolve chromate, perhaps not as good as hydrochloric (it is substantially weaker).
methods
Alright thanks man i will take note of that
Related Threads on Barium chromate
  • Last Post
32K
  • Last Post
  • Last Post
  • Last Post
10K
