- #1
EvLer
- 458
- 0
A, and B both are 16 bits wide; A is entity to shift and B is by how much;
we are supposed to implement a BARREL shifter. And here's the explanation (which does not make much sense to me, esp. the example) given in lab document:
A barrel shifter is a combinational logic device that incrementally shifts in stages. In our barrel shifter, we will have 4 stages. Each stage can choose to shift or not to shift, giving any total shift amount. For example, to shift an input by 9, stages one and four will shift 1 time and 8 times, respectively. Stages two and three will not shift. Notice that the binary number 9 is "1001". How convenient that the fourth bit and the first bit are 1 and the second and the third bits are 0.
ok, I know how to write the shift register, a regular without the "barrel", and after some googling, I found that barrel basically shifts by the amounts of bits specified at once. If someone could explain how the description from the lab document makes sense that is all i need to understand... thanks in advance.
