- 10
I really don't know much about circuit design, but I have built a device and it requires a LED indicator when power is applied to the load.
I also need a very low parts count.
The Problem. As I have designed it the LED glows ever so dimly when ac voltage is removed and when power is removed and electric motor spins down the LED pulse with the stator rotation.
I thought I could simply add a 1N4007 diode to fix the problem, but after a failed attempt i'm not sure how to wire it in or if I don't understand the solution.
The second problem is I don't understand about load vs neutral on the AC receptacle does it make a difference how i hook it up based on my diagram attached?
Thanks so much in advance for anyones help.
Shane
PDF of electrical diagram attached
Shane
