1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Basic comparison test
  1. Aug 13, 2009 #1
    the only thing i can think of is
    1/n^2>=1/n! , 1/n^2 being a convergent p series since p >1
    thus /n! is convergent
  3. Aug 13, 2009 #2
    nameVoid could you start putting some effort into your posts perhaps? In particular use the template and state your question plus your work clearly.
  4. Aug 13, 2009 #3
    whats the syntax for definite integral
  5. Aug 13, 2009 #4
    You should split off the first few terms to make the comparison with 1/n^2 more accurate.
    The syntax for a definite integral is [ tex] \int_{lowerlimit}^{upperlimit} [ /tex].
    This is not true for all n, take n=2 for example.
  6. Aug 13, 2009 #5
    If you are investigating the series
    \sum_{n=1}^\infty \frac{1}{n!}
    then you can use
    \sum_{n=1}^\infty \frac 1 {n^2}
    and compare terms (and the second series IS a convergent p-series: I'm not sure what Cyosis was getting at).
  7. Aug 13, 2009 #6
    I was getting at the fact that for the first few terms the inequality doesn't hold. So concluding right away that one converges may bit a bit of a jump hence I suggested to write out the first few terms until the inequality indeed holds.
  8. Aug 13, 2009 #7
    [tex]\frac{1}{n!}\leq\frac{1}{n^2} , n\geq 4[/tex]
    [tex]\sum_{n=1}^{\infty}1/n^2:convergent [/tex]
    i believe there is a property which states that if
    is convergent then the series converges for all n>=1 in any case here are the first few terms
    this seems to confirm things
  9. Aug 13, 2009 #8
    Looks fine to me. Good work. But you might want to prove that 1/n! <= 1/n^2 for n>= 4.
  10. Aug 13, 2009 #9
    Staff: Mentor
    Just as a side note, a series almost identical to yours--
    [tex]\sum_{n = 0}^{\infty}\frac{1}{n!}[/tex]
    -- converges to a number that is familiar to all mathematicians. Note that 0!, by definition, is 1.
  11. Aug 13, 2009 #10
    Does the question state explicitly that you need to use the Comparison Test? If not, then you may want to try using the Ratio Test, which I think works equally well in this case and you don't need to do induction to check what you're comparing this against actually works.
    Denote [tex]a_n = 1/n![/tex]. Then see that [tex]\lim_{n \to \infty} |a_{n+1}/a_n| = \lim \dfrac{1}{(n+1)!}\cdot n! = \lim \dfrac{n!}{(n+1)n!} = \lim \dfrac{1}{n+1} = 0 = \limsup |a_{n+1} / a_n| < 1 [/tex]. Thus, by the Ratio Test, this converges.
Similar Threads - Basic comparison test Date
Basic First ODE and Separation problem Dec 28, 2017
Basically solved, Last coordinate does not match? Oct 7, 2017
Basic Comparison Test Nov 1, 2011
Comparison test for basic integral Sep 25, 2011
Basic series comparison test Aug 12, 2009
