How tall is the flagpole on the roof of the Factory?
  • Thread starter cc_blue_cc
  • Tags
    Height
In summary, the conversation discusses a problem about finding the height of a flagpole based on the number of times a string wraps around it. The suggested techniques include using calculus and finding the parametric equations of the curve representing the string, as well as a simpler method of unrolling the flagpole and using Pythagoras' theorem.
cc_blue_cc
The flagpole on the roof of the Factory is 13 cm in diameter and a perfect cylinder. If one end of a 2300-cm-long string is attached to the top of the flagpole, and wraps around the flagpole exactly 16 times before ending at the bottom of the flagpole, how tall is the flagpole? Please round to the nearest centimetre, and submit only a number.
You must show your attempt if you desire help. Have you tried the usual stuff like drawing a picture or looking at your notes for something relevant?
One technique that comes to mind is to find the equation(s) of the curve in space along which the string lies, and then find the arclength of that curve. This technique requires the use of calculus, which is probably inappropriate for a question posted in the Precalculus Math forum. On the other hand, newbies often post their questions to the wrong forum, so maybe this technique is applicable.
Assuming that's the case, the parametric equations for the curve that represents the string are
x = 6.5cos t
y = 6.5 sin t
z = Kt
where 0 <= t, and K is a constant that needs to be determined so that if the string is wrapped around the pole 16 times it reaches the top of the pole.
There is a much easier way to do this problem.
No kidding! That's exactly what I was thinking... :biggrin:
Well, hey, if your only tool is a hammer, everything looks like a nail!:biggrin:
An easier way would be to "unroll" the flagpole and see how far 1/16 of the string reaches. Did you have in mind something like this?
Draw the net of the flagpole, and where the string would be. You will need pythagorus theorem.
1. What is the standard height of a flagpole?
The standard height of a flagpole is 20 feet (6.1 meters). However, this may vary depending on the location and purpose of the flagpole.
2. How do you measure the height of a flagpole?
The height of a flagpole is measured from the base of the pole to the top of the finial (the decorative ornament at the top). This measurement does not include any additional height from a flag or flagpole topper.
3. Is there a maximum height for a flagpole?
The maximum height for a flagpole varies by location and may be regulated by local or national building codes. In the United States, the maximum height for a flagpole is typically 35-40 feet (10.7-12.2 meters).
4. How does the height of a flagpole affect its stability?
The taller a flagpole is, the more susceptible it is to wind and other weather conditions. For this reason, taller flagpoles may require additional support, such as guy wires, to ensure stability.
5. Can a flagpole be taller than a building?
Yes, a flagpole can be taller than a building. However, this may depend on the height restrictions in a specific area. Taller flagpoles may also require special permits and additional safety measures to be installed.
  • Mechanical Engineering
  • Science Fiction and Fantasy Media
