The webpage title could be: Subgroups in (R^2,+) with Component-wise Addition
In summary, the set of ordered pairs with addition defined component wise is a group. However, the set {(x,2x+1)|x£R} is not a subgroup because it does not contain the identity element of the group, (0,0).
PsychonautQQ
784
Let (R^2,+) be the set of ordered pairs with addition defined component wise. Verify {(x,2x)|x£R} is a subgroup and that {(x,2x+1)|x£R} is not a subgroup.
So for something to be a subgroup it has to have all it's set items contained in the main group and be a group on it's own.
To be a group on it's own it has to have an identity e and an operation (in this case +) so that:
e+g = G
and an inverse so that (in this case a negative number with same magnitude)
g + (-g) = 0
and be assosciative
(g+h)+k = g+(h+k)
and it seems both (x,2x) and (x,2x+1) satisfy all these properties.
Furthermore, it seems that both (x,2x) and (x,2x+1) have all their combinations included in the main group. How is (x,2x+1) not a subgroup? What am I missing here?
e+g = G
I presume you mean e+ g= g.
g + (-g) = 0
and be assosciative
(g+h)+k = g+(h+k)
Since you are using ordinary addition, (x, 2x+ 1)+ (y, 2y+ 1)= (x+ y, 2x+1+ 2y+ 1)= (x+ y, 2(x+ y)+ 2) which is NOT of the form (a, 2a+ 1).
You are missing the fact that if H is a subgroup of G, and x and y are any elements of H, then x+y must also be an element of H.
The operation of the subgroup is the same as the operation of the full group. Thus you already know that the operation is associative, that there is a unique identity [itex]e \in G[/itex], and that every [itex]g \in G[/itex] has a unique inverse [itex]g^{-1} \in G[/itex].
To show that [itex]H \subset G[/itex] is a subgroup, you must show the following (in order of being easiest to check):
  • Identity: [itex]e \in H[/itex].
  • Inverse: If [itex]h \in H[/itex] then [itex]h^{-1} \in H[/itex].
  • Closure: If [itex]h_1 \in H[/itex] and [itex]h_2 \in H[/itex] then [itex]h_1h_2 \in H[/itex].
Here [itex]H = \{(x, 2x + 1) : x \in \mathbb{R}\}[/itex] falls at the first hurdle: [itex](0,0) \notin H[/itex].
Pasmith has noted something important in his post. If the origin isn't included, then it can't be a subgroup. Any line with a y intercept that isn't 0 can't form a subgroup.
So ##(x,2x)## will form a subgroup, but ##(x,2x + b)## for any ##b ≠ 0## will not.
1. What is group theory?
Group theory is a branch of mathematics that studies the properties and structures of groups, which are mathematical structures that consist of a set of elements and a binary operation that combines any two elements to produce a third element.
2. What are the basic properties of a group?
The basic properties of a group include closure, associativity, identity, and inverses. Closure means that the result of combining any two elements in the group is also an element in the group. Associativity means that the order in which elements are combined does not affect the result. Identity means that there is an element in the group that, when combined with any other element, results in that same element. Inverses means that every element in the group has an element that, when combined with it, results in the identity element.
3. How is group theory used in science?
Group theory has many applications in science, including in physics, chemistry, and biology. It is used to study symmetries in nature, such as the symmetries of molecules in chemistry or the symmetries of fundamental particles in physics. It is also used to classify and analyze complex systems, such as crystal structures or DNA sequences.
4. What is the difference between a group and a subgroup?
A subgroup is a subset of a group that satisfies the properties of a group. This means that all the elements in a subgroup must also be elements in the original group, and the subgroup must also have the same binary operation and fulfill the same basic properties as the original group.
5. Can you give an example of a group in real life?
One example of a group in real life is a Rubik's cube. The set of all possible configurations of the Rubik's cube forms a group, with the binary operation being the rotation of the cube's faces. The basic properties of groups can be seen in the fact that any sequence of moves on the cube can be undone by simply reversing the sequence, and that there is a specific sequence of moves that will return the cube to its original solved state.
