Basic Magnetic Sources help
  • Thread starter blackbyron
Wire #1 carries a current of 8.0A along the +x-axis. Wire #2 has a current of 6.1A along the +y-axis. What is the magnitude of the magnetic field at the point (1.4,1.3)m
I'm not sure if Long straight conductor will be the right formula to solve for magnetic field.
B = uo*I/(2*pi*r)
I spend an hour trying to solve this basic problem. I kept reading the textbook, reading my teachers notes, but doesn't seem helpful. They only show an example of one wire, but not two wires.
So then I found the r by using the Pythagorean theorem.
I understand that the current isn't the vector. but how am I suppose to solve the magnetic field if there are two currents, but both are perpendicular?
Thanks,
Byron
Answers and Replies
Redbelly98
Staff Emeritus
Insights Author
12,134
161
First find the magnetic field that you would get from just one of the wires. Then do the same thing for the other wire.
Paying attention to the direction of each magnetic field you calculate, you then simply add them using vector addition. Remember that the two magnetic fields are vectors; don't simply add their values unless they happen to point in the same direction.
Hope that helps.
Hope that helps.
Thanks for your reply,
yes I think I did that, though, but somehow I did
B= B * i(hat) + B* j(hat)
Is that right, because I'm getting one wrong. I think I'm not understand this.
Redbelly98
Staff Emeritus
Insights Author
12,134
161
We still need to figure out the direction of the magnetic field vectors (it's not in the i-hat or j-hat directions.) Have you been taught about the right hand rule for straight wires? Here is a figure:
You can read more details at the following link; scroll down to the section titled Right-Hand Rule #2:
http://physicsed.buffalostate.edu/SeatExpts/resource/rhr/rhr.htm
Yes I did learn the right hand rule, and I mostly understood them. But I think I understand how to do it since my friend helped me. But thanks for the link. I'll look into it for future use.
Related Threads on Basic Magnetic Sources help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
