Basic matrices
converting1
65
for fixed ## m \geq 2 ## let ## \epsilon (i,j) ## denote the mxm matrix ## \epsilon (i,j)_{rs} = \delta _{ir} \delta _{js} ##
when m = 2000 show by formal calculations that
i) ## \epsilon (500,199) \epsilon (1999,10) = \epsilon (500,10) ##
ii) ## \epsilon (1999,10) \epsilon (500,1999) = 0##
hence generalise for ##\epsilon (i,j) \epsilon (k,l)## and find a single equation using the kroneeker delta symbol for the generalisation
my attempt thus far:
i) rewriting this as ##\delta _{500r} \delta _{1999s} \delta _{1999r} \delta _{10s} ## then we note that ## \delta _{1999s} \delta _{1999r} = \epsilon (1999,1999) ## which gives a 0 everywhere except the 1999th ith position and 1999th jth position but I'm not sure how I can conclude that this gives ##\epsilon (500,10)##
that's all Ihave so far unfortunately
Answers and Replies
tiny-tim
25,836
255
hi converting1! :smile:
i) rewriting this as ##\delta _{500r} \delta _{1999s} \delta _{1999r} \delta _{10s} ## …
nooo …
##(\epsilon (i,j) \epsilon (k,l))_{r,s} = (\epsilon (i,j))_{r,t} (\epsilon (k,l))_{t,s}## :wink:
converting1
65
nooo …
oh damn im so stupid, so here is what I got so far let me know if my logic is flawed:
i) ## (\epsilon (500,1999))_{r,t} (\epsilon (1999,10))_{t,s} = \delta _{500r} \delta _{1999t} \delta _{1999t} \delta _{10s} ##
we know that ##\delta _{1999t} \delta _{1999t} = 1 ## if t = 1999, else it will be 0, so we get the required result
for ii) ## (\epsilon (1999,10))_{r,t} (\epsilon (500,1999))_{t,s} = \delta _{1999r} \delta _{10t} \delta _{500t} \delta _{1999s} ## we now see that ## \delta _{10t} \delta _{500t} = 0 ## as if t = 10, then ## \delta _{500t} = 0 ## and if t = 500 then ## \delta _{10t} = 0 ## hence we will get 0 always, the desired result
now generalising,
consider ## (\epsilon (i,j) \epsilon (k,l))_{rs} = (\epsilon (i,j))_{r,t} (\epsilon (k,l))_{t,s} = \delta _{ir} \delta _{jt} \delta _{kt} \delta _{ls} ##
## \delta _{jt} \delta _{kt} = 1 ## if j = k, else it's 0, hence we get ## \delta _{ir} \delta _{ls}## if j = k, i.e. we get ## \epsilon (i,l) ## if j = k, else we get 0.
now for the final part I am not sure how to express it as a single equation, could you give me a little hint?
tiny-tim
25,836
255
ah, you're still not thinking in terms of the summation convention:
##\delta _{1999t} \delta _{1999t} = 1 ## :wink:
similary ##\delta _{10t} \delta _{500t} = 0 ##​
once you've convinced yourself of this, you should be able to do the general case :smile:
converting1
65
hmm, I'm not so sure I understand, what if t = 20? i.e. ##\delta _{1999,20} \delta _{1999,20} = 0.0 = 0 ? ##
converting1
65
also take a 2x2 matrix as an example, ## \epsilon (1,2) _{22} = \delta _{12} \delta_{22} = 0 \times 1 = 0 ##
tiny-tim
25,836
255
ah, that's right, you don't understand …
you can't substitute one value for t into δ1999,tδ1999,t
the einstein summation convention means that that's a ∑ …
(over all values of t) δ1999,tδ1999,t :wink:
converting1
65
really? our lecturer defined ## \epsilon (i,j) _{r,s} = 1 ## if r = i and j = s , else it is 0, so I am just using that definition
so how do you know ## \delta_{1999,t} \delta_{1999,t} = 1 ##?
tiny-tim
25,836
255
has your lecturer not taught you the summation convention (the einstein summation convention)?
converting1
65
No, not yet, however in my applied mathematics lecturer we just started it today - so I know very little about it (almost nothing).
tiny-tim
25,836
255
oooh :redface:
ok: this sort of question is very difficult to do without either the summation convention or a ∑
whenever you see a δr,s, you know it's going to be multiplying something else with either an r or an s (or both)
and since all these things are parts of matrices, you know it's actually going to be a matrix multiplication:
A = BC means Ar,s = ∑(all values of t) Br,tCt,s
you can either write it with a ∑ (like that),
or you can use the summation convention and just write Ar,s = Br,tCt,s (with a "∑" being understood but not written)
that enables you to say "δr,s replaces any s in the thing next to it by r", eg δr,sAs,u = Ar,u
alternatively, use a ∑ : ∑ δr,sAs,u = Ar,u
in particular, δr,sδs,u = δr,u
(or ∑s δr,sδs,u = δr,u)
ok, try all that in the original question :smile:
converting1
65
oooh :redface:
ok using all for part c):
## (\epsilon (i,j) \epsilon (k,l) )_{r,s} = \displaystyle \sum_{t=1} ^{n} \epsilon (i,j) _{r,t} \epsilon (k,l) _{t,s} = \displaystyle \sum_{t=1}^{n} \delta _{ir} \delta _{jt} \delta _{kt} \delta _{ls} = \displaystyle \sum_{t=1}^n \delta _{ir} \delta _{jt} \delta _{jt} \delta _{ls}## if j = k, which then is ## = \delta _{ir} \delta _{jj} \delta _{jj} \delta _{ls} + \displaystyle \sum_{t \not= j } \delta_ {ir} \delta _{jt} \delta _{kt} \delta _{ls} = \delta _{ir} \delta _{ls} + 0 = \epsilon (i,l) ## if ## j \not= k ## then we get ## \displaystyle \sum_{t=1}^n \delta _{ir} \delta _{jt} \delta _{kt} \delta _{ls} = 0 ## as t cannot equal k and j simultaneously
is that ok?
converting1
65
what is part c) ? :confused:
sorry I didn't label in the original post part c is this:
" hence generalise for ##\epsilon (i,j) \epsilon (k,l)##"
tiny-tim
25,836
255
no, that last item should be ## = \displaystyle \delta _{ir} \delta _{jk} \delta _{ls}##
and then rewrite that as ##= \delta _{jk} (\delta _{ir} \delta _{ls})##
so now you have ##(\epsilon (i,j) \epsilon (k,l) )_{r,s}= \delta _{jk} (\delta _{ir} \delta _{ls})##
sooo … ? :smile:
(btw, you don't need to write "\displaystyle" on this forum :wink:)
converting1
65
sooo … ? :smile:
## = 1\times \epsilon (i,l) ## ?
is everything else correct that I've written?
tiny-tim
25,836
255
nearly :smile:
(what happened to the δjk ? :wink:)
converting1
65
nearly :smile:
is it not 1 if j = k??
tiny-tim
25,836
255
yes, but you want a general formula for ## \epsilon (i,j) \epsilon (k,l) ## :wink:
converting1
65
I'm really not sure what to put
tiny-tim
25,836
255
say it (partly) in words, starting "ε(i,j)ε(k.l) is … ", and then we'll put it completely into symbols :smile:
converting1
65
it's epsilon(i,l) if j = k else it's 0,
thanks for your patience
tiny-tim
25,836
255
ok, so it's epsilon(i,l) times … ? :smile:
converting1
65
## \delta _{jk} ## ?
tiny-tim
25,836
255
(just got up :zzz:)
yes!!
ε(i,j)ε(k,l) = δjkε(i,l) :smile:
work your way through it, and compare it with parts (i) and (ii), until you're convinced how it works :wink:
converting1
65
thank you tim, really appreciate it.
Suggested for: Basic matrices
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
