How Do You Solve Basic Mechanics Problems in Physics?
  • Thread starter azwraith69
  • Tags
    Mechanics
In summary, for number 1 you can use the equation F=ma to solve for the unknown variable, for number 2 and 3 your solutions are correct, just make sure to label the direction correctly.
azwraith69
attached below..
#2:[tex]\Sigma[/tex]Fx = max [tex]\Sigma[/tex]Fy = may
#3:[tex]\Sigma[/tex]Fx = 0 [tex]\Sigma[/tex]Fy = 0
#1: none.. don't know what to do yet
#2:
[tex]\Sigma[/tex]Fx = F1cos30 + F2cos45 - f = max
ax = (F1cos30 + F2cos45 - f) / m = (10cos30 + 14.1cos45 - 10) / 9 = 0.96m/s2
[tex]\Sigma[/tex]Fy = F1sin30 + F2sin45 = may
ay = (F1sin30 + F2sin45) / m = (10sin30 - 14.1sin45) / 9 = -0.55m/s2
magnitude of a = sqrt(0.962 + (-0.55)2) = 1.1m/s2
direction of a = tan-1 [tex]\frac{-0.55}{0.96}[/tex] = -29.8o or 29.8o south of east
#3:
[tex]\Sigma[/tex]Fx = FMcos33 - FVcos= 0
FVcos[tex]\theta[/tex] = FMcos33 = 60cos33 = 50.32N
[tex]\Sigma[/tex]Fy = -FMsin33 + FVsin[tex]\theta[/tex] - w= 0
FVsin[tex]\theta[/tex] = 50N + 60sin33 = 82.68N
magnitude of FV = sqrt(50.322 + 82.682) = 96.8N
direction of FV = tan-1[tex]\frac{82.68}{50.32}[/tex] = 58.67o
please help me with number 1.. i have no idea how to solve it..
the answers on the book for number 1 are: a)4.2m/s b)29.4 m/s^2 c)4310N
is there anything wrong with numbers 2 and 3??
thanks in advance
  • problems.doc
for your help!
Hello! For number 1, you can use the equation F=ma to solve for the unknown variable. You know the mass (m=5kg) and acceleration (a=2m/s^2), so you can rearrange the equation to solve for force (F). The equation would look like this: F=ma=5kg x 2m/s^2 = 10N. So the answer for part a) is 10N.
For part b), you can use the same equation F=ma, but this time the unknown variable is the mass (m). You know the force (F=20N) and acceleration (a=2m/s^2), so you can rearrange the equation to solve for mass (m). The equation would look like this: m=F/a=20N/2m/s^2=10kg. So the answer for part b) is 10kg.
For part c), you can use the equation F=mg to solve for the unknown variable. You know the mass (m=1000kg) and acceleration due to gravity (g=9.8m/s^2), so you can rearrange the equation to solve for force (F). The equation would look like this: F=mg=1000kg x 9.8m/s^2=9800N. So the answer for part c) is 9800N.
Your solutions for numbers 2 and 3 look correct. Just make sure to label the direction as either north, south, east, or west. For example, for number 2 the direction would be 29.8o south of east. Great job on those problems!
1. What is the difference between static and dynamic equilibrium?
In static equilibrium, an object is at rest and all forces acting on it are balanced, resulting in zero net force. In dynamic equilibrium, an object is moving at a constant velocity and all forces acting on it are balanced, resulting in zero net force and zero acceleration.
2. How do I calculate the net force on an object?
The net force on an object is calculated by adding all the forces acting on the object together, taking into account their direction and magnitude. This can be done using vector addition.
3. What is Newton's First Law of Motion?
Newton's First Law of Motion, also known as the Law of Inertia, states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force.
4. How do I calculate the acceleration of an object?
The acceleration of an object can be calculated by dividing the net force acting on the object by its mass. This is represented by the equation F=ma, where F is the net force, m is the mass, and a is the acceleration.
5. What is the difference between mass and weight?
Mass is a measure of the amount of matter in an object, while weight is a measure of the force of gravity acting on an object. Mass is measured in kilograms (kg) and weight is measured in Newtons (N).
