Homework Help: Basic Momentum Question
  1. Mar 6, 2016 #1
    A 0.30kg puck A, moving at 5m/s [W], undergoes a collision with a 0.40 puck B which is initially at rest. Pick A moves off at 4.2m/s [W 30deg N]. Find the final velocity of Puck B.
    2. Relevant equations
    pi=pf
    mvi=mvf
    3. The attempt at a solution
    Let [N] and [W] be positive
    Puck A
    vix = 5m/s
    m1= 0.30kg
    vf=4.2m/s
    vfx : 4.2cos30=3.6m/s
    vfy : 4.2sin30=2.1 m/s
    Puck B
    vi=0m/s
    m2=0.40kg
    Solve for v2fx
    m1v1ix + m2v2ix = m1v1fx + m2v2fx
    (0.30)(5)+(0.40)(0)=(0.30)(3.6)+(0.40)v2fx
    2.43= v2fx
    Solve for v2fy
    m1v1iy + m2v2iy = m1v1fy + m2v2fy
    (0.30)(0)+(0.40)(0)=(0.30)(2.1)+(0.40)v2fy
    -1.58 = v2fy
    Find the resultant v2f
    |v2f| = sqrt((2.43)2+(1.58)2)
    |v2f| = 2.9 m/s
    tantheta = (1.58/2.43)
    theta = tan-1(1.58/2.43)
    theta = 33deg
    Final answer: velocity of Puck B is 2.9m/s [33deg SW].
    Can someone tell me if I'm doing this correctly?:
  3. Mar 6, 2016 #2
    haruspex
    That step looks wrong.
    By the way, you should keep some more decimal digits during the calculation or you may find the final result is rather inaccurate.
  4. Mar 6, 2016 #3
    Corrected it, I got v2fx=3.47 m/s and theta now = 25 degrees.
    Does that seem correct now?
  5. Mar 6, 2016 #4
    haruspex
    Still wrong. Please post all your working.
  6. Mar 6, 2016 #5
    Ok one second
  7. Mar 6, 2016 #6
    Ok one second
  8. Mar 6, 2016 #7
    1.5+0=1.08+0.40v2fx
    0.42=0.40v2fx
    0.42/0.40=v2fx
    1.05= v2fx
    | v2 | = sqrt((1.05)2+(1.58)2)
    = 1.9m/s
    tantheta = (1.58/1.05)
    theta = tan-1(1.58/1.05)
    theta = 56 degrees
    Answer: velocity of puck B is 1.05m/s [56deg SW]
    How about now? Is my process wrong, or is it the math- this is what I get for doing my work at 6am lol.[/QUOTE]
  9. Mar 6, 2016 #8
    haruspex
    That all looks ok now. "56 deg SW" is not a clear way of stating it. Better is "56 deg S of W".
    Edit: You should get into the habit of doing very rough mental estimates to check your answers.
    In the equation you were handling wrongly, you could see the puck A lost 1.4m/s of its x velocity, and it weighs only 3/4 of puck B. So puck B's x velocity must be 3/4 of 1.4m/s.
  10. Mar 6, 2016 #9
    Ok thanks so much for you help!
  11. Mar 6, 2016 #10
    Is that just a shorter way of performing the calculation?
  12. Mar 6, 2016 #11
    haruspex
    whether it is shorter depends on exactly how you solved the equation. If you multiplied out all the terms first then yes it is. But more generally the numbers might have been a lot more awkward. The point is to do a mental check in terms of the approximate ratios and differences. E.g. if the masses had been 0.31 and 0.39 I would still have called it 3/4.
  13. Mar 6, 2016 #12
    Ok thanks for your help!
Have something to add?
Draft saved Draft deleted
Loading...
