Basic Number Series
  • Thread starter CWatters
CWatters
2,315
My son has just started learning about number series and has managed to do all of his homework except for two questions that have him and me stumped. To give you some idea of the level he's at most of the questions were simple number series.. eg Find the nth term in 9, 2, -5, -12 to which the answer is -7n+16.
The two questions we are stuck on are:
1. Homework Statement
Q3) What is the equation for the nth term of the series.. 7, 11, 14, 15
Q4) What are the next two number in the series 0, 1, 1, 2, 5, 8, ?, ?
None
Q3) Sorry if the formatting is off....
Original 7 11 14 15
1st Dif 4 3 1
2nd Dif -1 -2
3rd Diff -1
So it might be a cubic quadratic (third level difference -1) but there aren't enough given numbers to be certain and anyway he hasn't covered quadratic series yet let alone cubic quadratic.
Q4) Not a clue.
Photocopies of the questions were provided so no typos unless the teacher made them.
We're missing something but what?
Answers and Replies
97
The second question looks suspiciously like a Fibonacci sequence, which is recursively defined. Are you missing a 3 after the 2?
fresh_42
Mentor
Insights Author
2021 Award
16,680
16,002
I have a construction rule for the first one, Q3).
If ##n## is odd, say ##n=2k-1##, then build ##Q_3(n) = 7k##.
If ##n## is even, say ##n=2k##, then build ##Q_3(n) = 7+2^{k+1}##.
The next numbers would then be 21, 23, 28,...
The point is: this is voodoo! For any number ##N## you can find a sequence, i.e. a construction rule for which ##N## is the following number to your given ones. It's nothing very serious and I wouldn't pay too much attention on it. If you answer: 346298 and 57 are the next numbers of Q4) no one can ever prove you're wrong. It's more a "guess what I mean" than a serious mathematical task.
fresh_42
Mentor
Insights Author
2021 Award
16,680
16,002
Brilliant idea! Now I have a construction rule for Q4), too.
Build the Fibonacci sequence ##F_n = F_{n-1} +F_{n-2}## and drop every 5th member although calculating with it.
See: One can always find something weird and declare it as a construction rule.
CWatters
2,315
Yes that popped up when I googled the numbers but the problem sheet definitely hasn't got a 3 in the sequence.
I also googled the sequence in the other question 7 11 14 15 which turns up in an obscure list of "numbers with at least one 1 and one 2 in ternary (base 3) representation"...
http://oeis.org/A125293
7 in base 3 is 21
11 in base 3 is 102
14 in base 3 is 112
15 in base 3 is 120
but the question asks for the nth term rather than the next two numbers so I can't see how this is relevant if at all.
CWatters
2,315
Will be interesting to see what answer the teacher gives.
CWatters
2,315
F and M.
Is that meant to be a hint about how to solve my questions?
fresh_42
Mentor
Insights Author
2021 Award
16,680
16,002
F and M.
No. It's a joke. And it shows the arbitrariness of such exercises. Btw: most mathematicians have much more trouble to find F and M :wink:
haruspex
Insights Author
7,783
Agreed, which is why one should expect that the shorter the given sequence the simpler the rule.
Certainly Q4 is a misprint for the Fibonacci sequence. Since we are only given 4 numbers in Q3 it should be even simpler, so I very strongly suspect another error. Maybe 7, 11, 14, 16?
SammyS
Staff Emeritus
1,158
Q3: Perhaps these numbers are written in base eleven.
In base ten the sequence is: 7, 12, 15, 16, which could be a quadratic.
fresh_42
Mentor
Insights Author
2021 Award
16,680
16,002
Only that ##16_{11} = 17_{10}##.
Edit: Sorry, I was reading haruspex' corrected version ... (Where's my deletion button gone?)
Related Threads on Basic Number Series
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
