Homework Help: Basic question about Force
  1. Oct 19, 2011 #1
    I am trying to find out if force in newtons can be negative.
    If i know the magnitude of decelaration of a car ( a minus acceleration ) and i know the mass, do i multiply the - acceleration value by the mass, resulting in a minus value in newtons, or do i multiply the mass by the deceleration, resulting in a positive value in newtons.
    2. Relevant equations
    for example, 1500kg ( mass ) x -2 m s-2 ( acceleration ) = -3000 newtons
    3. The attempt at a solution
    I think this would be correct because the minus is telling us the direction in which the force is being applied, but i really am not sure, any advice would be appreciated?
  3. Oct 19, 2011 #2
    A force is a vector, it cannot have a negative magnitude. Although what you see as -3000 newtons is really just a contradiction of the direction. The 3000 newtons is acting in the direction opposite to the one you assumed it's acting in.
    F=ma, should actually be |F|=m|a|, or [tex]\vec{F} = m \vec{a}[/tex]
    EDIT: Sorry, just read your attempt at solution. You're right, it corresponds to the direction.
  4. Oct 19, 2011 #3
    Hi, thank you for your reply. So if i were to write the answer as -3000 newtons would that be correct? Or should it be 3000?
    Many thanks.
  5. Oct 19, 2011 #4
    Hiii zoezoehzoe !
    Force is a vector quantity but that doesn't even mean that it has to be negative. However I came across some text books which claim the answers in -500 N etc. It is not a big deal but this is not correct. It is wrong ! As Ahmedbasil said that force is vector because of direction. It has magnitude as well as direction.
    |F| = m x |a| ---> This is a correct representation.
    Cross product of vector(acceleration) and scalar(mass) is always vector(force).
    Vector quantity : Direction + Magnitude + can be negative or remain absolute OR only magnitude but negative ; Example: Displacement , acceleration , velocity etc .
    Scalar quantity :Only Magnitude ;and only positive . Eg. Distance , speed , mass etc .
    In F=ma , acceleration has nothing to do with direction even. It just tells increase or decrease in velocity per unit time. Force is dependent on direction. Example : Centripetal force in centre due to constant change in direction.
    I recommend you should write 3000 N as your answer.
    ___________________________________________________________
    Ahmedbasil , you are correct to say that -X N means force is applied in opposite direction but you must not say that it is because it is causing retardation in opposite direction. Retardation = -(-Acceleration).
    Positive and negative sign in acceleration just tell that whether speed is increasing (velocity for particular) or decreasing.
    :wink:
    Always feel free to ask questions. Well done !
  6. Oct 19, 2011 #5
    Thank you both very much for your help :)
Loading...
