Basic question on input impedance
  • Thread starter temujin
temujin
47
Hi,
I have a HF transmitter rated with 200mW output power. An antenna is connected to the transmitter via a 50 ohm coax cable. (The antenna is also matched to 50 ohm.)
Does this mean that from the transmitters point of veiw, a 50 ohm resistor is connected as load?
Can I find the current in the antenna circuit simply by applying ohm´s law?
(I^2 = P/Z). I´m pretty sure I can´t, but I´m not sure why...
If not, what does actually the power rating of the transmitter imply?
regards
t.
Answers and Replies
mmwave
211
temujin said:
Hi,
That the idea. If the cable is perfect and matched to the load you have the equivalent of a 50 ohm load at the output of the transmitter. In reality the antenna won't be perfectly 50 ohms with no reactance and the cable isn't perfect but if you bought them from a reliable source it should be good enough.
To the extent you truly have a 50 ohm antenna & a 50 ohm characteristic impedance cable this is exactly how you would calculate it. To be any more accurate would require a measurement of the cable + antenna or else a SWR meter connected between transmitter & cable. From that you can work out the actual magnitude of the impedance. To do better you need a network analyzer.
When the source and load aren't perfectly matched the concept of current loses a lot of its value. The current will vary sinusoidally with distance. The maximum possible current (for load of zero ohms) would be twice the current in your equation. The max possible voltage (for a open load) would be calculated similarly. Don't do these experiments to prove it - you will destroy your transmitter.
The power rating is always for a specified load impedance giving a perfect match to the transmitter output, usually 50 ohms except for cable tv systems.
Suggested for: Basic question on input impedance
  • Last Post
