Finding Valence Numbers of Elements: A Guide for Relearning Chemistry
In summary, the conversation discusses the process of writing chemical formulas, specifically for aluminum chloride. The "crossover rule" is applied to determine the formula, and the valence numbers of aluminum and chlorine are obtained from a table. The question is raised about how to determine the valence number for other elements, and the conversation delves into the relationship between valence numbers and the groups in the periodic table. The use of oxidation states and ions is also mentioned. The speaker suggests practicing with some molecular formulae to gain a better understanding of compounds and their valence numbers.
Jchem
28
Hello all, I'm re-learning chemistry on my own and have a quick question that I can't find the answer to in my book.
Its about writing formulas.
For example, aluminum chloride. I know that Al has a valence number of +3, and I know that Cl has a valence number of -1.
So applying the "crossover rule" the answer is AlCl3.
Now the only reason I know the valence numbers of Aluminum and Chlorine is because I got them from a Valence number table with about 10 different elements.
My question is, how do I figure out the valence number for all the other elements?
thanks
Chemistry news on Phys.org
well i that staring from helium over to boron you can count helium at 0 and fluorine at one and so on an count it columes as the # to but if Al has the valance of three that would prove me other wise
b=5 al=3? :confused:
c=4 si=4
n=3 p=3
o=2 s=2
fl=1 cl=1
c=4 si=4
n=3 p=3
o=2 s=2
fl=1 cl=1
Why would boron be 5? It has two inner shell electrons and 3 outer shell electrons (the valance ones). It has a proton number of 5 but Aluminium has a proton number of 13 yet it has a valance of 3.
The groups in the periodic table will give you a fair number of the valence electrons e.g. Sodium has 1 outer shell electron, Potassium has one as well and they form Sodium/Potassium Chloride with Chlorine (outer shell of 7). Group 2 have 2 valance electrons etc. (although consider that it is easier for group 6 and 7 to gain electrons).
However you must also wish to know about the transition metals. All I have to say is that these can be predicted but it really does take knowledge of oxidation states and the like. Copper can form compounds where where 2 of the other element is need, simply one is needed or two coppers are needed. This is oxidation state use.
Also a knowledge of ions is needed (e.g. OH- has a charge of minus one. You may have been able to work this out due to oxygen being a 2- ion and hydorgen being a +1 ion. However SO42- has a charge of minus 2. This is another workable one but it is not obvious and some people do put them seperately, which can be confusing).
I am not sure how to answer the question to the stand you want it because it does need some understanding first. I think it might be wise if I post some questions and you try answering them:
What is the molecular formulae for:
(a) Sodium oxyide?
(b) Potassium fluoride?
(c) Calcium oxide?
(d) Magnesium chloride?
(e) Methane (Carbon and Hydrogen)?
(f) Calcium carbonate?
(g) Potassium hydroxide?
(h) Hydrochloric Acid?
(i) Sulphuric Acid?
(j) Uranium Hexafluride (just for fun)
This will allow you to see if you understand the basis of compounds and, thus, the valance of elements. Then this can progress to the transition metals when the basis is there.
The Bob (2004 ©)
P.S. I apologise if this post seems unneccesary or patronising. This was not the point at all.
1. What is a valence number?
A valence number, also known as an oxidation number, is a numerical representation of the charge on an element in a compound. It indicates the number of electrons an atom has gained, lost, or shared in order to achieve a stable electron configuration.
2. Why is it important to know the valence numbers of elements?
Knowing the valence numbers of elements is essential in understanding how they will react with other elements and compounds. It also helps in predicting the type of bond that will form between elements and the overall chemical reactivity of a substance.
3. How can I determine the valence number of an element?
The valence number of an element can be determined by looking at its electron configuration in the periodic table. The number of valence electrons is equal to the element's group number. For transition metals, the valence number can vary and needs to be calculated using other factors.
4. Can valence numbers change?
Yes, valence numbers can change depending on the type of chemical reaction. In ionic compounds, valence numbers will change as atoms gain or lose electrons. In covalent compounds, valence numbers remain the same since electrons are shared.
5. How can I use valence numbers to write chemical formulas?
Valence numbers can be used to determine the ratio of elements in a compound, which is necessary for writing chemical formulas. The valence number of each element is used as a subscript next to the element symbol to indicate the number of atoms present. For example, the compound sodium chloride (NaCl) has a valence number of +1 for sodium and -1 for chlorine, resulting in the formula NaCl.
10K
  • Quantum Physics
  • Chemistry
