Basic questions on relativity terminology
  • Thread starter Dixanadu
Hi guys,
Can someone explain - as simply as possible - what the following terms mean?
1) Lorentz observer
2) Lorentz frame
3) spacelike vector
Thanks guys!
Answers and Replies
phinds
Insights Author
2021 Award
17,670
9,625
Have you looked anywhere for definitions?
Yes I have read in books but 1) and 2) are often used without any explanation.
As far as 3) is concerned, I know what spacelike separation is, but I'm not sure what a spacelike vector is. 1) and 2) are more important for me right now!
phinds
Insights Author
2021 Award
17,670
9,625
I can't imagine what search phrase you are using but I put in "what is a lorentz frame" and got plenty of explanations.
Dale
Mentor
Insights Author
2021 Award
32,850
10,045
2) Lorentz frame
A Lorentz frame is an inertial frame (force-free motion is in a straight line at constant speed) using Einstein's synchronization convention.
Thank you for clarifying! Could you also tell me what a Lorentz observer is? or it is just someone in a lorentz frame?
Dale
Mentor
Insights Author
2021 Award
32,850
10,045
I would have to see the context, although I could probably guess. It isn't a standard term that I am aware of.
In general I don't like the pedagogical obsession with observers. It gives the impression that relativity is about optical illusions.
By the way, everyone is "in" every frame. They may be "at rest in" or "moving in" any given frame, but either way they are "in" it.
Okay thank you. I hate to keep persisting but there is one more thing which I am a bit confused about.
What does it mean if something is Lorentz invariant? Say for example a typical lorentz transformation is given by [itex]\Lambda^{\mu}_{\hphantom{x}\nu}[/itex], and that we want to check if some object, say [itex]\phi[/itex], is invariant under it. How would you go about doing it?
Dale
Mentor
Insights Author
2021 Award
32,850
10,045
No problem. "Lorentz invariant" is a standard term. It just means that the object in question does not change under a Lorentz transformation. So to check, all you have to do is find the value in one frame, transform into the other frame, and check that it is the same.
http://www.mathpages.com/home/kmath398/kmath398.htm
15,864
A spacelike vector is a vector that points in a spacelike direction. If you think of a point in spacetime, and then consider nearby points, there will be a vector at the chosen point that points towards each of the nearby points. If a particular nearby point is spacelike separated from the chosen point, then the vector that points towards it from the chosen point is a spacelike vector.
jtbell
Mentor
15,871
4,495
As DaleSpam noted, context is important. My guess is that it means an observer who is at rest in a Lorentz frame.
Related Threads on Basic questions on relativity terminology
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
D
