What is the intersection of A and the union of B and C?
  • Thread starter blunted
  • Tags
    Sets
In summary, the question is asking for the outcome of the expression (A∩B) U (C∩A) when A = {a,b,c} and B U C = {c,d,e,f}. The solution involves finding the intersection of A and B, as well as the intersection of C and A, and then taking the union of those two results. Simplifying the expression, we get {c} as the final answer.
blunted
23
A = {a,b,c} ; B U C = {c,d,e,f} ; (A∩B) U (C∩A) = ?
A U B U C = {a,b,c,d,e,f}
A ∩ {B U C } = {c}
My answer: {c}
do it in steps:
- A intersect B = { ... }
- C intersect A = { ... }
then union the results
Oops just saw you don't have B or C so you need to do set relations as you've shown to get B union C in the mix.
So I think you're right, the answer is { c }
Let's just make it on an easy notation where intersection is multiplication and union is sum:
[tex]
A\times B+C\times A=A\times(B+C)=A\times\left\{c,d,e,f\right\}=\left\{ c\right\}
[/tex]
Thanks.
1. What is a basic set?
A basic set is a fundamental collection of objects or elements that share a common characteristic or property. These elements can be numbers, shapes, colors, or any other defined criteria.
2. What is the difference between a basic set and a universal set?
A basic set is a subset of a universal set, which is a larger set that contains all possible elements. A basic set only contains a specific group of elements that meet a certain criteria, while a universal set encompasses all possible elements.
3. How are basic sets useful in mathematics?
Basic sets are useful in mathematics for categorizing and organizing data or information. They also serve as building blocks for more complex mathematical concepts and theories.
4. Can a basic set be empty?
Yes, a basic set can be empty if there are no elements that meet the defined criteria. For example, the set of even numbers between 1 and 3 would be an empty basic set.
5. What is the difference between a basic set and a proper set?
A basic set is a subset of a larger set, while a proper set is a subset that does not contain all elements of the larger set. In other words, a proper set is a basic set that is not equal to the universal set it belongs to.
