Homework Help: Basic Sinusoidal Waveform Problem
  1. Nov 6, 2012 #1
    2. Relevant equations
    ω=2[itex]\pi[/itex]f
    3. The attempt at a solution
    After converting it from time domain to phasor domain
    my answer is I=17.6[itex]\angle[/itex]25mA.
    How am I suppose to show the current at time = 2 sec? Do I just plug in 2 and find the sine of it?
  3. Nov 6, 2012 #2
    berkeman
    Staff: Mentor
    That's what I would do...
  4. Nov 6, 2012 #3
    So the answer is 6.47mA? Or is it I=17.6∠25mA? I don't understand what the hint is referring to.
  5. Nov 6, 2012 #4
    berkeman
    Staff: Mentor
    That answer looks okay to me. The hint (more of a reminder) is just saying to always be careful to be consistent in the units of the argument to the sin() function. Since they show the 25 with a degrees sign on it, you need to check that the 250t term is also in degrees. By inspection it seems plausible that it is, since radian measurements will generally have a ∏ in them somewhere. If the function were 25sin(3∏t + 25o), then you would need to convert one or the other into different units, and make sure your calculator was set to those units when calculating the answer.
    Make sense?
  6. Nov 6, 2012 #5
    I typed two answers, 6.47mA and I=17.6∠25mA, which answer are you saying looks okay?
    I thought the hint imply that what I was originally doing was wrong (where I originally arrived at I=17.6∠25mA ) because I had to do something with the 2 seconds which I did not do.
  7. Nov 6, 2012 #6
    berkeman
    Staff: Mentor
    To be honest, I haven't been understanding what you were trying to do with the phasor. Your 6.47mA answer is correct, I believe. 25sin(525o) = 6.47
  8. Nov 6, 2012 #7
    Hmm, okay, it just seems to easy to be a question, this question feels kind of ambiguous because I don't think that was what the professor wants. Thanks for the input.
  9. Nov 7, 2012 #8
    I don't like how that question is worded. Just be sure that 250t is in degrees and not radians.
    The phasor has nothing to do with this question.
    A phasor is another representation of a sinusoid where the time-varying part (ejwt) has been factored out. It's as if you wrote down the sin equation in another form and it won't tell you what value the waveform has at a specific time (t=2) unless you convert it back to sinusoidal form, plug t=2 into it and take the real part.
    However, to be clear, you should mark the 25 in the angle part as 25 degrees because without units it could be understood to be in radians.
