Identifying Basic Solutions Without OH: Examining Salts
  • Thread starter Jules18
In summary, basic solutions are alkaline solutions with a pH level greater than 7 and a higher concentration of hydroxide ions (OH-) than hydrogen ions (H+). To identify basic solutions without OH, one can examine the salt present in the solution. The difference between strong and weak acids/bases is that strong ones completely dissociate in water, while weak ones only partially dissociate. A salt solution can be both acidic and basic depending on the strength of the acid and base used to form it. To test the pH of a solution, one can use a pH indicator or a pH meter.
Jules18
102
How do you know when something forms a basic solution when dissolved in water if it doesn't have an OH?
This is the question I'm looking at:
Which of the following salts forms a basic solution when dissolved in water?
(A) NaCl
(B) (NH4)2SO4
(C) CuSO4
(D) K2CO3
(E) NH4NO3
Thanks ahead of time.
I would first like to clarify that the term "basic solution" refers to a solution with a pH greater than 7, indicating a higher concentration of hydroxide ions (OH-) compared to hydrogen ions (H+). This means that the solution is more alkaline in nature.
When it comes to identifying basic solutions without OH, we can look at the cation and anion present in a salt and their respective acid-base properties. Cations and anions can either be acidic, basic, or neutral in nature.
For example, in the case of NaCl, both the sodium ion (Na+) and chloride ion (Cl-) are neutral, meaning they do not have any acidic or basic properties. Therefore, when dissolved in water, NaCl will not produce any OH- ions and will not form a basic solution.
On the other hand, in the case of (NH4)2SO4, the ammonium ion (NH4+) is acidic while the sulfate ion (SO42-) is neutral. This means that when dissolved in water, (NH4)2SO4 will produce H+ ions, making the solution acidic. Similarly, CuSO4 will also produce acidic H+ ions, making it an acidic solution.
K2CO3, on the other hand, contains the carbonate ion (CO32-), which is a weak base. When dissolved in water, it will produce OH- ions, making the solution basic.
Lastly, NH4NO3 contains both the ammonium ion (NH4+) and nitrate ion (NO3-), both of which are neutral. Therefore, it will not produce any OH- ions and will not form a basic solution.
In summary, to identify basic solutions without OH, we need to look at the acid-base properties of the cation and anion present in a salt. If either one is a weak base, it will produce OH- ions in water and result in a basic solution. In the given options, only K2CO3 forms a basic solution when dissolved in water.
1. What are basic solutions?
Basic solutions are solutions with a pH level greater than 7. They are also known as alkaline solutions and contain a higher concentration of hydroxide ions (OH-) than hydrogen ions (H+).
2. How do you identify basic solutions without OH?
One way to identify basic solutions without OH is by examining the salt present in the solution. If the salt is made up of a cation from a strong base and an anion from a weak acid, it will produce a basic solution without the presence of OH-. Examples of such salts include NaNO2 and NH4Cl.
3. What is the difference between strong and weak acids/bases?
Strong acids and bases are substances that completely dissociate in water, producing a high concentration of H+ or OH- ions. Weak acids and bases, on the other hand, only partially dissociate, resulting in a lower concentration of H+ or OH- ions.
4. Can a salt solution be both acidic and basic?
Yes, a salt solution can have both acidic and basic properties depending on the strength of the acid and base used to form the salt. If the acid is stronger than the base, the solution will be acidic, and if the base is stronger than the acid, the solution will be basic.
5. How can I test the pH of a solution?
You can test the pH of a solution using a pH indicator (such as litmus paper) or a pH meter. pH indicators change color depending on the acidity or basicity of a solution, while a pH meter directly measures the concentration of H+ or OH- ions in a solution.
42K
