Solving Basic Tension Problems: Newton Readings on Calibrated Spring Balances
  • Thread starter maniacp08
  • Tags
    Tension
In summary, the conversation is discussing the use of spring balances calibrated in Newtons to measure the tension in strings attached to objects on an incline. The question is how much tension is in the string when the objects are in mechanical equilibrium. The conversation also touches on the relationship between mass and weight, and the use of force diagrams to solve for tension. The correct answers for the tension in each case are 10N, 0N, 5N, and 49.05N respectively.
maniacp08
115
In the figure below, the objects are attached to spring balances calibrated in Newtons. Give the readings of the balances in each case, assuming that the strings are massless and the incline is frictionless.
Im kinda confuse on what the question ask but here is what I think.
Does this relate to Hooke's Law Fx = -KX?
If it is there is 2 unknowns. I know Fx = to the weights but X?
Could you tell me if this is correct?
For
A) is it 10N?
B) 0N
C)5N
D) ?
"Does this relate to Hooke's Law Fx = -KX?"
Not really. The spring balance in each case measures the tension in the strings. In each case there is mechanical equilibrium. The question is really: How much tension is in the string if the masses in each situation are in mechanical equilibrium?
One other point: don't forget the relationship between mass (kg) and weight or force (N).
Could you elaborate on that? I am still confuse on what you mean by that
You'll need to draw a force diagram for each mass.
The masses are not moving since they are in equilibrium. That simplifies the well-known equation F=ma.
The string tension will enter into the net force. Since the string tension is the balance reading, solving for the tension will answer the questions.
Your answers are incorrect, however you are pretty close on (a) and (c). Question: what is the weight of a 10 kg mass?
10kg * 9.81 for A
and for C is the answer for A/2?
F = MA
F = M * 9.81?
How come for B is not 0? and How would I approach for D?
maniacp08 said:
10kg * 9.81 for A
Yes, pretty much, except that it is 9.81 N/kg, not just 9.81 (if you want to do the units properly, that is).
F = MA
F = M * 9.81?
The acceleration of an object at rest is not 9.81.
Draw the force diagram for the masses.
Net Force = MA, and A = ____ for an object at rest.
B: the string tension is not zero. Draw a force diagram for each mass.
D: Draw a force diagram for each mass.
For D.
The force of gravity is 98.1N
The Normal force is cos(30) * 98.1N
Since there is 10kg mass pulling on the string, I need to find the force
so is sin(30) * 98.1N which is 49.05N
Is that the answer?
maniacp08 said:
For D.
... 49.05N
Is that the answer?
Yes.
Thanks so much for helping! =]
What is the "Basic Tension Problem"?
The "Basic Tension Problem" is a scientific concept that refers to the force that is generated when an object is pulled or stretched in opposite directions. This force is known as tension, and it can be seen in many everyday situations, such as a rope being pulled or a rubber band being stretched.
What factors affect the tension in a system?
The tension in a system is affected by several factors, including the weight and mass of the object being pulled, the force applied to the object, and the material properties of the object. In addition, the angle at which the force is applied can also impact the tension in the system.
How is tension calculated?
Tension is calculated by multiplying the mass of the object by the acceleration due to gravity and adding any additional forces acting on the object. This calculation is known as Newton's Second Law of Motion and is expressed as F = ma, where F is the force, m is the mass, and a is the acceleration.
What are some real-world applications of tension?
Tension has many real-world applications, including in construction, engineering, and sports. For example, tension is used in the design of bridges and buildings to ensure they can withstand the force of gravity and other external forces. In sports, tension is used in the design of equipment, such as tennis rackets and fishing rods, to improve performance and accuracy.
How can tension be managed or controlled?
Tension can be managed and controlled through various methods, including adjusting the weight and mass of the object, changing the angle at which the force is applied, and using different materials with varying properties. In addition, proper maintenance and regular inspections can help prevent tension-related issues, such as structural failures.
  • Classical Physics
