Sabre1
- 3
Okay, I need some help understanding some of the Thermo principles and I found this forum. I hope someone can help.
I'm working on Energy Analysis of a closed system. Conservation of energy principle and all that. deltaU = Q-W. Every time I think I know what should be considered work and what should be considered internal energy (U), etc. I am proven wrong.
In one example we have a room where we are disregarding any heat transfer through walls and doors. We are given a constant room volume, an initial Pressure and Temperature, the Wattage of a running fan and an amount of Time that the fan is running for. We are asked if the room cools down,which of course it will not because no heat is being removed and the work from the fan will add heat to the room.
Q=0 and we are left with deltaU = -W
delta U = Wattage * Time = kJ
that is one thing that confuses me because I would have thought the work by the fan would = Work or negative work whatever the case might be.
The problem boils down to
delta U = mass * Cv * (T2-T1) and we solve for T2
(mass and Cv were calculated for air from data given)
What happened to work? I'm confused.
