Basics of Fluid Mechanics and Pressure
In summary, the conversation discusses the forces acting on a liquid molecule at the surface of a liquid, including atmospheric pressure, pressure from the surrounding liquid, and the weight of the molecule. There is also mention of buoyancy and surface tension as additional forces to consider. The conversation also touches on the complexity of analyzing forces on molecules and the applicability of certain equations at the molecular level. Finally, the conversation delves into the pressure at the surface of a liquid and how it is affected by factors such as surface tension and the container's acceleration.
  • #36
Tanya Sharma said:
When the elevator is not accelerating then ##Mg = V_1ρg## .
When the elevator is accelerating up then ##Mg = V_2ρ(g+a)## .
##V_1 = V_2(1+\frac{a}{g})## or ##V_1>V_2## . The displaced fluid when the elevator is accelerating is less i.e the block sinks less ( moves upwards ) as compared to when the elevator is at rest .
Is this what you are suggesting ?
No. Try that force balance again, and this time use a free body diagram on the block.
Chet
  • #37
##V_1ρg -Mg = 0##
##V_2ρ(g+a) - Mg - Ma = 0## i.e ##V_1=V_2## ?
  • #38
Tanya Sharma said:
##Mg - V_1ρg = 0##
Yes. This is what will happen after the block stops bobbing. Initially, there will be a transient, and the block will dip and then bob, but, after the transient bobbing dies out, the displaced volume will be the same as without the acceleration.
Chet
  • #39
On second thought, I take back what I said about the dip and bobbing. There should not be a transient even if the acceleration is applied suddenly. Sorry for the confusion.
  • #40
If we write Newton's 2nd law for the block in the ground frame (not from the accelerated frame) .
##F_{b1} - Mg = 0##
##F_{b2} - Mg = Ma## i.e ##F_{b2} =M(g+a)##
##F_{b2} > F_{b1}## . Since the buoyant force is more in accelerating elevator case , fluid displaced should be more . This is the same reasoning I gave in post #29 .
What is the flaw in this reasoning ?
  • #41
##F_{b1} - Mg = 0##
##F_{b2} > F_{b1}## . Since the buoyant force is more in accelerating elevator case , fluid displaced should be more . This is the same reeasoning I gave in post #29 .
If the water is considered incompressible, then the buoyant force imposed by the water will respond instantly to the acceleration. Your second equation here confirms the analysis in post # 37 showing that the displacement will be the same.
Chet
Likes Tanya Sharma
  • #42
it is [itex]F_{b2}>F_{b1}[/itex] but because the fluid weights more now (it is like the gravitational acceleration g is increased by a) not because there is more volume of fluid displaced.
Likes Chestermiller and Tanya Sharma
  • #43
You are right .
  • #44
Chet
There is an ice cube floating in a glass of water . What happens to the water level if
1) ice cube has a cavity with air inside(the cavity).
2) ice cube has a cavity with water inside(the cavity) .
I think that the water level goes down in the first case and remains same in the second case .
Do you agree ?
  • #45
Tanya Sharma said:
Chet
Do you agree ?
I don't quite understand the question. The base case of comparison is a solid ice cube?
Chet
  • #46
No . The comparison is with the level of water present in the glass before the ice melts .Sorry for being unclear .
What happens to the original water level if
1) an ice cube having a cavity with air inside(the cavity) , floating on the water melts.
2) ice cube having a cavity with water inside(the cavity) , floating on the water melts .
Do you agree ?
  • #47
Do you agree ?
Off hand, I find it rather tricky to reason out. Why don't you just model it, and let the math do the work for you? I would do either a cubical cavity or a spherical cavity.
Chet
  • #48
I have done the maths(not much involved) . Just wanted to reassure myself by confirming the result with you :)
  • #49
I confirm your result for item 2. For item 1, it depends on whether you take into account the slight density of the air. If you include the density of the air, then the level goes down slightly, but, if you neglect the density of the air, then I get no change.
Chet
Likes Tanya Sharma
  • #50
I vent done the math but in the first case you assume that after the ice cube melts, the air is released to the atmosphere or dissolved into the water?
  • #51
Please tell us your thoughts on this.
Chet
