Basis of a Vector Space
In summary, the conversation discusses proving that a list of vectors is a basis of a vector space by showing that it is either linearly independent or spans the space. The attempt at a solution shows that \vec{w}, \vec{v_2}, ... , \vec{v_n} is linearly independent and therefore forms a basis of V. This can be shortened by using a theorem stating that a set of n linearly independent vectors in an n-dimensional space will automatically span the space.
Izzy
Let V be a vector space, and suppose that [itex]\vec{v_1}[/itex], [itex]\vec{v_2}[/itex], ... [itex]\vec{v_n}[/itex] is a basis of V. Let [itex]c\in\mathbb R[/itex] be a scalar, and define [itex]\vec{w}[/itex] = [itex]\vec{v_1} + c\vec{v_2}[/itex]. Prove that [itex]\vec{w}, \vec{v_2}, ... , \vec{v_n}[/itex] is also a basis of V.
If two of the following conditions hold, the third holds automatically, and the list is a basis for a vector space V.
1. If dimV = the number of vectors in the list.
2. If the list of vectors spans V.
3. If the list of vectors is linearly independent.
So, I feel like I did this right, but I have no way to check because we don't use a textbook for the class and I couldn't find it online anywhere. I did the following.
Since [itex]\vec{v_1}[/itex], [itex]\vec{v_2}[/itex], ... [itex]\vec{v_n}[/itex] is a basis of V, [itex]\vec{v_1}[/itex], [itex]\vec{v_2}[/itex], ... [itex]\vec{v_n}[/itex] are linearly independent and span V. Also, dimV = n, because n vectors form the basis of V.
[itex]\vec{w}, \vec{v_2}, ... , \vec{v_n}[/itex] is also a list of n vectors, so it will be sufficient to show that this list either spans V or is linearly independent in order for it to be a basis of V.
Since [itex]\vec{v_1}[/itex], [itex]\vec{v_2}[/itex], ... [itex]\vec{v_n}[/itex] span V, that means there exists some scalars ai (where i is between 1 and n inclusive) such that
a1v1 + a2v2 + ... + anvn = [itex]\vec{x}[/itex], where [itex]\vec{x}[/itex] is in V.
So, for [itex]\vec{w}, \vec{v_2}, ... , \vec{v_n}[/itex] to span V, there must exist some scalars bi such that b1w + b2v2 + ... + bnvn = [itex]\vec{x}[/itex].
Then I basically expand this, and set it equal to the previous expression with all the a's. I show that in order for them to be equal, choose b3 = a3, b4 = a4, ... bn = an.
Then all we have to show is that
b1v1 + (b1c + b2)v2 = a1v1 + a2v2.
Choose b1 = a1, and b2 = a2 - a1c.
Then a1w+ (a2 - a1c)v2 + a3v3 + ... + anvn = [itex]\vec{x}[/itex], so it spans V.
Thus, since the dimension if n and it spans V, it also forms a basis of V.
Is this right, though?
Looks ok to me... :rolleyes:
There is a theorem that a set of ##n## linearly-independent vectors in an ##n##-dimensional space ##V## does, indeed, span ##V##. If you know and are allowed to use that theorem, you can shorten your argument a bit: just show that ##\vec{w}, \vec{v}_2, \ldots, \vec{v}_n## are linearly independent.
The OP said in his first post
3. If the list of vectors is linearly independent. "
so, yes, he does know that.
I missed the opening sentence.
I tried it like that first, but I couldn't actually figure out how to show that ##\vec{w}, \vec{v}_2, \ldots, \vec{v}_n## are linearly independent. Can I have a hint for how to do that?
Also, I'm a girl btw. :P
The message you are quoting above said nothing about your gender!
Anyway, you want to know if there are ##c_1, c_2, \ldots, c_n##, not all zero, such that ##0 = c_1 w + c_2 v_2 + \cdots + c_n v_n = 0##. Take it from there.
I think I got it.
Let ##c_3, ... c_n = 0##, and now we'll show that ##c_1w + c_2v_2## = 0.
##c_1(v_1+cv_2) + c_2v_2 = 0##
##c_1v_1+c_1cv_2 + c_2v_2 = 0##
##c_1v_1 + (c_1c+c_2)v_2 = 0##
##c_1## must be 0, because it's the only way to get rid of ##v_1##, so then ##c_2## must also be 0.
Thus call the constants must be zero, so it's linearly independent?
Izzy said:
I think I got it.
I don't think you have it. In the equation #c_1v_1 + c_2v_2 + \cdots + c_nv_n = 0##, the fact that all of the constants ci = 0 means absolutely nothing. This happens when the vectors are linearly independent and when they are linearly dependent. The important fact for a set of linearly independent vectors is that there is only a single solution in the constants with all of them being zero.
##c_1 w + c_2 v_2 + \cdots + c_n v_n = 0##
##\Rightarrow c_1(v_1 + cv_2) + c_2 v_2 + \cdots + c_n v_n = 0##
I would get an equation with only the vectors v1, v2, ..., vn in it, and then use the fact that this set of vectors is linearly independent.
You quoted Ray Vickson, but it was HallsofIvy who said "so, yes, he does know that."
So, do you mean that I should just say
##c_1(v_1 + cv_2) + c_2 v_2 + \cdots + c_n v_n = 0##
##c_1v_1 + (c_1c+c_2)v_2 + ... + c_nv_n = 0 ## is linearly independent because ##v_1, v_2, ... v_n## are linearly independent?
Also, I know HallsofIvy said it, I just didn't go back and quote him. I figured he'd figure it out lol.
In the second form of the sum all of the coefficients of the v's must be zero since the v's are linearly independent. What does that tell you about ##c_1, c_3, ...##?
You can't describe an equation as "linearly independent". You're trying to show that w, v2, ..., vn are a linearly independent set.
Well, you confused Ray Vickson, whom you quoted, and who thought you were talking about him.
That they're 0. So the only way to make the second sum 0 is if ##c_2## is also 0. And since the second sum is equivalent to the first sum, all the coefficients must still be 0, so w, ##v_2, ..., v_n## are linearly independent?
Sorry Ray Vickson! Thought you were joking, not confused.
You're still missing an important concept. Given any vectors v1, v2, ..., vn in the same space, you can always write this equation: ##c_1v_1 + c_2v_2 + \cdot + c_nv_n = 0##. The vectors could be linearly independent or linearly dependent.
If the vectors are linearly independent, then there is one and only one solution, the trivial solution: c1 = c2 = ... = cn = 0. If the vectors are linearly dependent, then there is also a solution for which at least one of the constants is nonzero.
Pretty much. Since ##c_1 c + c_2=0## and ##c_1=0## the whole sum reduces to ##c_2 v_2=0##. Since ##v_2## is nonzero (why?) that tells you ##c_2## must also be zero.
What is a vector space?
A vector space is a mathematical structure that consists of a set of objects called vectors, along with rules for combining those vectors and multiplying them by numbers. These rules are known as vector addition and scalar multiplication, and they must satisfy certain properties in order for the set to be considered a vector space.
What are the basic properties of a vector space?
The basic properties of a vector space include closure under addition and scalar multiplication, associativity and commutativity of addition, distributivity of scalar multiplication over addition, and the existence of an additive identity element (zero vector) and a multiplicative identity element (scalar 1).
What is the basis of a vector space?
The basis of a vector space is a set of linearly independent vectors that span the entire vector space. This means that any vector in the space can be expressed as a unique combination of the basis vectors, using scalar multiplication and vector addition. The number of basis vectors is known as the dimension of the vector space.
How do you determine the basis of a vector space?
To determine the basis of a vector space, you can use the Gaussian elimination method to find the linearly independent vectors in a set of vectors that span the space. Alternatively, you can also use the rank-nullity theorem, which states that the dimension of a vector space is equal to the number of vectors in a basis plus the dimension of the null space (set of all vectors that get mapped to the zero vector by a linear transformation).
Why is the concept of vector space important in mathematics and science?
The concept of vector space is important in mathematics and science because it provides a general framework for understanding and analyzing a wide range of mathematical objects and physical phenomena. It allows us to represent and manipulate complex systems and relationships in a concise and elegant way, making it a fundamental tool in fields such as linear algebra, physics, and engineering.
  • Linear and Abstract Algebra
