Basis of the range of a Linear Transformation
In summary, we are given a (4x5)-matrix A over R, and a linear transformation L_A: R^5 --> R^4 defined by L_a(x) = Ax. By row reducing the augmented matrix [A | b], we can find the basis for the range of L_A, which is given by the set of vectors {(b1, b2, b3, b4) in R^4 | b1 - 3b3 + 2b4 = 0 and b2 - 2b3 + b4 = 0}. Since there are two pivot columns, the basis will consist of two vectors that satisfy the given equations. One way to find these vectors is to choose b
WK95
139
Mod note: fixed an exponent (% --> 5) on the transformation definition.
A is a (4x5)-matrix over R, and L_A:R^5 --> R^4 is a linear transformation defined by L_a(x)=Ax. Find the basis for the range of L_A.
##A = \begin{bmatrix}1 & 2 & 3 & 4 & 5 \\2 & 3 & 4 & 5 & 6 \\3 & 4 & 5 & 6 & 7 \\4 & 5 & 6 & 7 & 8 \end{bmatrix}##
##A = \begin{bmatrix}1 & 2 & 3 & 4 & 5 & b_{1} \\2 & 3 & 4 & 5 & 6 & b_{2} \\3 & 4 & 5 & 6 & 7 & b_{3} \\4 & 5 & 6 & 7 & 8 & b_{4} \end{bmatrix} ##
##A = \begin{bmatrix}1 & 0 & -1 & -2 & -3 & -3b_{1}+2b_{2} \\0 & -1 & -2 & -3 & -4 & -2b_{1}+b_{2} \\0 & 0 & 0 & 0 & 0 & b_{1}-2b_{2}+b_{3} \\0 & 0 & 0 & 0 & 0 & 2b_{1}-3b_{2}+b_{4} \end{bmatrix}##
Where do I go from there?
Let's put some words with the above so that you can understand what's going on. For some b ##\in## R4, the augmented matrix above represents this matrix equation:
Ax = b
A bit of row reduction yields the above. Note that I didn't check your work, so it's possible there were some arithmetic errors along the way. Also, you should multiply row 2 by -1 so that the matrix is in proper reduced form.
The first two rows in the matrix tell us about x1 and the other coordinates of the input vector x. The first row tells us that x1 is a linear combination of x3, x4, and x5, plus a combination of some of the coordinates of b. The second row tells us that x2 is a different linear combination of x3, x4, and x5, plus some of the coordinates of b.
The last two rows tell us about the restrictions on b itself, namely that b1 - 3b3 + 2b4 has to be zero, as does b2 - 2b3 + b4. Do you see why?
From these restrictions you can solve for the coordinates of b, and thereby get a basis for the range of your transformation. I have glossed over things a bit here, but if what I've said isn't clear, ask for clarification.
Likes 1 person
Yes, I see why b1 - 3b3 + 2b4 and b2 - 2b3 + b4 have to equal zero. Since they are limiting what sort of values b1,b2, b3, and b4 can take, I'm guessing they have something to do with range?
In fact, they define the range.
Likes 1 person
Ah Ok. So the answer to the problem is
Rg(A) = {(b1,b2,b3): b1 - 3b3 + 2b4 = 0, b2 - 2b3 + b4=0}
Is the notation for the solution correct?
Would the basis in this case be two vectors (because there are two pivot columns?) that both fit the above rule for the range? For b1 - 3b3 + 2b4 = 0, b2 - 2b3 + b4=0, the free variables would be b3 and b4.
If i choose b3 and b4 to equal 1 and 2 respectively, b1 and b2 are -1 and 0 respectively.
If i choose b3 and b4 to equal 2 and 1 respectively, b1 and b2 are 4 and 3 respectively.
the two vectors I get are (-1,0,1,2) and (4,3,2,1) assuming I did this correctly. Would these be the basis?
Not quite. Each vector b in the range has four coordinates, not three as you show. And rather than showing the two equations, I would give the range as a set of two vectors in R4.
What is usually done is to choose b3 = 1 and b4 = 0 to get one vector, and then choose b3 = 0 and b4 = 1 to get the other vector.
If they satisfy the two equations you started with, they're fine. My choices would be <3, 2, 1, 0> and <-2, -1, 0, 1>, though. Your two vectors and my two vectors are linearly independent, since each vector in a pair is not a scalar multiple of the other one in the pair. If it turned out that there were three or more vectors in a basis, my technique would be better, since it would be obvious that the three (or more) vectors were linearly independent. This is because in certain coordinate positions, all but one vector would have 0's in that position, so it wouldn't be possible for any vector to be a linear combination of the others.
Likes 1 person
So how about this?
##Rg(A)= \begin{bmatrix}1 \\0 \\-3 \\2 \end{bmatrix}, \begin{bmatrix}0 \\1 \\-2 \\1 \end{bmatrix} ##
WK95 said:
So how about this?
Nope. These are just the two rows of your reduced matrix. If you check, you'll see that they don't satisfy the two equations in the b coordinates.
To get your basis vectors, note that the first row stands for b1 - 3b3 + 2b4 = 0, and the second row stands for b2 - 2b3 + b4 = 0,
Solve the first equation for b1 and the second equation for b2. b3 and b4 are free variables. If you write the four equations, you'll see that <b1, b2, b3, b4> can be written as a linear combination of two vectors.
So
b1 = 3b3 - 2b4 = 0,
b2 = 2b3 - b4=0
b3=free
b4=free
So
##b_{3}\begin{bmatrix}3 \\2 \\1 \\0 \end{bmatrix}+b_{4}\begin{bmatrix}-2 \\-1 \\0 \\1 \end{bmatrix}##
or
##\begin{bmatrix}3 \\2 \\1 \\0 \end{bmatrix},\begin{bmatrix}-2 \\-1 \\0 \\1 \end{bmatrix}##
WK95 said:
So
b1 = 3b3 - 2b4 = 0,
b2 = 2b3 - b4=0
b3=free
b4=free
So
or
Bingo! That's exactly what I have.
Likes 1 person
And that's the basis?
Thanks for your help!
Those two vectors are a basis for the range of L.
Likes 1 person
Can you also check my answers for these questions?
Find the basis for the row space and column space.
The Basis of the Row Space is the first 2 rows (row vectors?) from the RREF form and the column space is the first two columns (column vectors?) of the original matrix.
Sounds about right.
Likes 1 person
How would I go about finding the basis of the kernel?
Solve the matrix equation Ax = 0, where A is the matrix of your transformation. Operationally, you could have an augmented matrix, with the last column all zeroes, but you can omit it since it cannot change. Get the matrix in RREF form and read off the values for x1, etc., exactly as you did when you found the range. This time, though, the solution will represent the vectors in R5 that get mapped to the 0 vector in R4.
The important part to remember is that you're finding the solutions to Ax = 0. Since there will be an infinite number of them, you want to present the kernel as a set of vectors that form a basis for it.
So x1=x3+2x4+3x5, x2=-2x3-3x4-4x5.
Would the solution be
Basis of kernel = {##\begin{bmatrix}0 \\0 \\1 \\2 \\3 \end{bmatrix},\begin{bmatrix}0 \\0 \\-2 \\-3 \\-4 \end{bmatrix}##}
Yes.
No.
This is the standard trick, so it pays to learn it.
Write the five equations.
Code:
x[SUB]1[/SUB] = x[SUB]3[/SUB] + 2x[SUB]4[/SUB] + 3x[SUB]5[/SUB]
x[SUB]2[/SUB] = -2x[SUB]3[/SUB] - 3x[SUB]4[/SUB] - 4x[SUB]5[/SUB]
x[SUB]3[/SUB] = x[SUB]3[/SUB]
x[SUB]4[/SUB] =        x[SUB]4[/SUB]
x[SUB]5[/SUB] =             x[SUB]5[/SUB]
If you look at this just right, you should see that a vector x in the kernel is a linear combination of three vectors.
So
Basis of kernel = {##\begin{bmatrix}1 \\-2 \\1 \\0 \\0 \end{bmatrix},\begin{bmatrix}2 \\-3 \\0 \\1 \\0 \end{bmatrix},\begin{bmatrix}3 \\-1 \\0 \\0 \\1 \end{bmatrix}##}
With those values being from the coefficients of x3, x4, and x5 respectively.
The 3rd vector isn't in the kernel. The other two are. You have a mistake in your row reduction or copied a number incorrectly.
Mark44 said:
Code:
Hmm... i doubled checked and the row reduction is correct. I'm not sure where I went wrong.
I got those three vectors from this which looks correct. How did you deduce that the last vector should not be there?
Mark44 said:
Code:
From the way I set up the three equations you can read off the three vectors. I checked my 3rd vector and it works, and yours doesn't. If you stare at what I wrote long enoughtm it should come to you.
Basis of kernel = {##\begin{bmatrix}1 \\-2 \\1 \\0 \\0 \end{bmatrix},\begin{bmatrix}2 \\-3 \\0 \\1 \\0 \end{bmatrix},\begin{bmatrix}3 \\-4 \\0 \\0 \\1 \end{bmatrix}##}
Wow.. I missed that. the -1 in the 3rd vector should of been a -4. Stupid me...
Right.
WK95 said:
Stupid me...
As a check, and something you should always do, multiply your matrix times each of the vectors in your basis. Since they are vectors in the kernel, the result of each multiplication should be the zero vector.
Likes 1 person
Mark44 said:
Right.
Thanks. That's very helpful to know!
Additionally, how do I "express 0 as an element of R^4 as a linear combination of the column vectors of A in which every scalar is nonzero?"
For one, I know the kernel is x such that Ax=0. Additionally, I know the basis of the kernel so i know that a certain linear combination of the vectors in the basis of the kernel will get me an answer or so I think. For sure, I'm certain that the kernel is involved somehow.
For your question above, it seems to me that you are asking how to show that the columns of the matrix are linearly dependent. Since there are five columns, and the columns are vectors in R4, they have to be linearly dependent. This means that the equation c1L1 + c2L2 + c3L3 + c4L4 + c5L5 = 0 has a solution in which at least one of the constants, ci is nonzero. (Here Li is the i-th column of the matrix.) That's how I understand what you're asking in the first question above.
I don't see much of a direct connection between this and what you say about the kernel. If you had a square matrix (same number of columns as rows) and if the columns were linearly independent, then the transformation that the matrix represents would be one-to-one, and the kernel would necessarily consist of only the zero vector.
1. What is a linear transformation?
A linear transformation is a mathematical function that maps one vector space to another vector space while preserving the properties of addition and scalar multiplication. In simpler terms, it is a transformation that maintains the "linearity" of a space.
2. What is the basis of a linear transformation?
The basis of a linear transformation is a set of vectors that span the entire vector space. These vectors are known as the basis vectors and they form the foundation for all other vectors in the space.
3. How is the range of a linear transformation determined?
The range of a linear transformation is determined by applying the transformation to all possible input vectors in the vector space. The resulting set of output vectors is known as the range and it represents all the possible values that the transformation can produce.
4. What is the relationship between the basis and the range of a linear transformation?
The basis of a linear transformation forms a set of vectors that can be used to represent any vector in the range of the transformation. In other words, the basis vectors span the range of the transformation.
5. How does the dimension of the basis affect the range of a linear transformation?
The dimension of the basis directly affects the dimension of the range of a linear transformation. This is because the number of basis vectors determines the number of dimensions in the vector space and, in turn, the number of dimensions in the range of the transformation.
