Chris Rorres
- 4
If A is an invertible matrix and vectors (v1,v2,...,vn) is a basis for Rn, prove that (Av1,Av2,...,Avn) is also a basis for Rn.
The basis of A with an invertible A matrix is the set of linearly independent columns of A. This means that each column can be expressed as a linear combination of the other columns, and no column is redundant.
To prove that A has an invertible matrix, we need to show that its columns are linearly independent. This can be done by setting up a system of equations using the columns of A and solving for the variables. If the only solution is the trivial solution (all variables equal to 0), then the columns are linearly independent and A has an invertible matrix.
No, if the columns of A are not linearly independent, then A cannot have an invertible matrix. This is because the columns of an invertible matrix must form a basis, and a basis must consist of linearly independent vectors.
The determinant of A is a measure of how much the volume of a parallelepiped changes when transformed by A. A has an invertible matrix if and only if its determinant is non-zero, meaning that the transformation does not collapse the volume of the parallelepiped to 0. In other words, if A has an invertible matrix, its determinant must be non-zero.
If A has an invertible matrix, then the system of linear equations can be solved for a unique solution using matrix operations. This is because an invertible matrix can be used to transform the system into an equivalent system with a unique solution. However, if A does not have an invertible matrix, then the system may have either no solution or infinitely many solutions.
