1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Basketball Problem
  1. Jan 24, 2005 #1
    :uhh: A basketball player throws the ball at a 38 degree angle to a hoop which is located a horizontal distance L=7.0m from the point of release, and at a height h=0.3m above it. What is the required speed if the basketball is to reach the hoop?
    help please o:)
  3. Jan 24, 2005 #2
    Use the equation for the projectile (it should be in your text book), then plug in the numbers and solve for the required speed.
  4. Jan 24, 2005 #3
    cepheid
    Staff Emeritus
    Strategy...as I mentioned to you in your true/false thread, horizontal and vertical components of the bball's velocity are independent. So...call the initial velocity you're trying to solve for v_0
    The x-component of the v_0 is unaffected throughout the journey. Therefore, you don't have a clue yet what to do with it. It is constant, so you need to know the time required for the ball to get there. That depends on how high it needs to go before stopping (the vertical component). So, just note for now that the x component is given by :
    [tex] v_0\cos(38^o) [/tex]
    and ignore it for the time being.
    Now, the vertical component of the velocity:
    [tex] v_0\sin(38^o) [/tex]
    is affected by the gravitational force, which causes a constant downward acceleration, which slows the ball's velocity by 9.81 metres per second, every second. So, how do you solve for the required initial vertical velocity, and the time needed to get the ball up to that height? There are three equations...one gives the vertical component of the velocity as a function of time, (which is useful to you, because you know the final vertical velocity is zero), the other gives the height h(t) as a function of time, in terms of the vertical velocity and and accelaration. The third is the fact that:
    [tex] [v_0\cos(38^o)]t [/tex] must be equal to three metres.
    Hopefully you know which kinematic formulas I'm talking about.
  5. Jan 25, 2005 #4
    i tried doing this problem by plugging in values into this equation:
    Vxo = Vx(cos38) Vyo=Vy(sin38)
    combining the two I found,
    y=(tan38)x - (g / 2(Vo^2)(cos38)^2)x^2
    however my answer was wrong.
    ( I tried your method aswell cepheid - but it was long and complicated - I think I got lost in the numbers along the way.) :s
  6. Jan 25, 2005 #5
    just wanna make it clear
    did you mean
    [tex]y = tan(38)x - \frac{g x^2}{2 v_{0}^2 cos^2(28)) [/tex]
    if yes, your answer should be fine, what numerical v you got?
  7. Jan 25, 2005 #6
    sort of yeah - except in the second part it would be (cos38)^2
    and whats frac?
    I found Vo = 6.115 m/s and it was wrong...:(
  8. Jan 25, 2005 #7
    that was a typo
    here you go
    [tex]y = tan(38)x - \frac{g x^2}{2 v_{0}^2 cos^2(38)} [/tex]
    let me check... 1 minute
  9. Jan 25, 2005 #8
    how did you write it out so clearly??
  10. Jan 25, 2005 #9
    i don't get your answer... let me try to figure out what you diid wrong...
  11. Jan 25, 2005 #10
    yes! thats the equation I used!! :smile:
    was it just a calculation error then? this is the right equation to use to solve the problem?
  12. Jan 25, 2005 #11
    I'll try it again - maybe i din't put brackets around certain #'s in my calculator or something...
  13. Jan 25, 2005 #12
    basically I plugged in:
    x = 7.0m
    y = 0.3m
    g = 9.8m/s^2
    and solved for Vo
  14. Jan 25, 2005 #13
    what is your Vo equal to... you might either have some algebra error or calculatioin error
  15. Jan 25, 2005 #14
    31.95m/s ??
  16. Jan 25, 2005 #15
    does that sound more feasible?
  17. Jan 25, 2005 #16
    i got 5 point something...
    sory, can't give you the answer, try again
  18. Jan 25, 2005 #17
    that answer didn't work either
    what am I doing wrong?
    ~ I only have 2 tries left :S
  19. Jan 25, 2005 #18
    ok
    well at least I know the approximate range of the answer right? hehe
  20. Jan 25, 2005 #19
    Vo = \sqrt{(tan(38)(7.0m) - \frac{(-9.8m/s^2) (7.0m)^2}{2 (0.3m) cos^2(38)}}
  21. Jan 25, 2005 #20
    well that didn't work out...
    here's how I manipulated the equation:
    Vo = Square root of { tan(38)x - ((-g)x^2 / 2ycos(38)^2) }
Similar Discussions: Basketball Problem
  1. Basketball problem (Replies: 7)
  2. Basketball Problem (Replies: 6)
Loading...
