Battery Operation: How Charges Move Inside a Closed Circuit
In summary, batteries work by pumping positive charges from their positive terminal to their negative terminal, creating an electric current that powers the circuit. This process is necessary for the flow of charges to continue and is based on the law of conservation of charge.
lisamay44
Inside the battery (we stress INSIDE the battery) in a closed circuit (consider the battery attached to a lightbulb with the light bulb glowing), the battery
(a) creates positive charge.
(b) pumps positive charge from its positive terminal to its negative terminal.
(c) creates negative charge.
(d) pumps positive charge from its negative terminal to its positive terminal.
I think that batteries pump current (positive charge) from the positive terminal to the negative terminal, because if batteries work due to an electric field, then the positive current would have to move toward the negative terminal. So based on this I think the answer is B. But batteries produce electrostatic potential energy so doesn't that mean it would create positive charge (A) as well?
So I guess I would go with B, but I'm really not sure.
Not quite. Think of it this way:
1.Remember the law of conservation of charge. Does this help you eliminate some wrong answers?
2.Inside the battery must take the charges from their ending point at one end of the battery and move them back to the other end, the starting point, to keep the current going. Thinking in terms of positive charge moving, what way do the charges move around the circuit? What side of the battery is the end point for their "journey?"
Well the law of conservation of charge states that charge cannot be created or destroyed in an isolated system, only transferred. So that rules out A and C.
So then in a closed circuit, the positive charges move outside the battery from the positive terminal, through the load, to the negative terminal. Once they arrive at the negative terminal, the battery has to "pump" them from the negative terminal to the positive terminal in order for this whole process to begin again. If the battery didn't pump the positive charge, then the circuit could not continue to work. Is this the correct thinking?
It seems that you got it. Good job.:smile:
1. What is the difference between a battery and a charge?
A battery is a device that stores chemical energy and converts it into electrical energy. It consists of one or more cells, which contain positive and negative electrodes separated by an electrolyte. A charge, on the other hand, refers to the amount of electricity that a battery can hold. The more charged a battery is, the longer it can power a device.
2. Can all batteries be recharged?
No, not all batteries can be recharged. Primary batteries, also known as disposable batteries, are designed to be used once and then disposed of. These include alkaline, lithium, and zinc-carbon batteries. Rechargeable batteries, also known as secondary batteries, can be recharged multiple times and include nickel-cadmium, nickel-metal hydride, and lithium-ion batteries.
3. How do batteries store energy?
Batteries store energy through a chemical reaction. When a battery is connected to a circuit, the chemical reaction between the positive and negative electrodes produces electrons, which flow through the circuit to power a device. As the battery is used, the chemical reaction depletes the materials in the electrodes, eventually leading to a loss of charge.
4. How long do batteries last?
The lifespan of a battery depends on various factors such as the type of battery, how it is used, and the conditions it is exposed to. Generally, primary batteries can last anywhere from a few months to a few years, while rechargeable batteries can last for hundreds or even thousands of charge cycles before needing to be replaced.
5. Can batteries explode?
In rare cases, batteries can explode due to a buildup of gas within the battery caused by a short circuit or overcharging. This is more likely to happen with lithium-based batteries, which have a higher energy density. To prevent explosions, it is important to use batteries properly and avoid damaging them. If a battery shows signs of damage or swelling, it should be disposed of properly.
  • Electromagnetism
  • Electromagnetism
