Battery and resistance
  • Thread starter ttsky
Hi every one,
I placed a multimeter probe across the terminals of a 1.5 v alkaline battery and saw 2 M Ohms, I did the same across a mV power supply at 1.5 volts and got little below 1.5 K ohms. I dont understand what makes them have diffrent resistance, and exactly why?
I did this because I had an odd situation with a SIL 2 (safty integrity level) rated gas analyser, the analyser would only work with a real sensor or a battery at correct voltage, but not a simulator (e.g mV supply).The diffrence as it seems is the sensor has very high impedance. So i measured the resistance of the battery and the supply, and now i am confused why the battery shows such high resistance.
Answers and Replies
berkeman
Mentor
61,319
11,845
Hi every one,
That's not how you measure the output resistance of a voltage source. The DMM resistance measurement is for passive devices, not for active sources of voltage or current.
Instead, make 2 output voltage and current measurements using 2 different resistors, and solve the 2 simultaneous equations for the source resistance of the voltage source. Are you familiar with that measurement technique?
jim hardy
Dearly Missed
9,847
4,889
ttsky: You might want to read up on how an ohmmeter works.
http://en.wikipedia.org/wiki/Ohmmeter
A more accurate type of ohmmeter has an electronic circuit that passes a constant current (I) through the resistance, and another circuit that measures the voltage (V) across the resistance. According to the following equation, derived from Ohm's Law, the value of the resistance (R) is given by: R= V/I
Related Threads on Battery and resistance
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
