Macgyverasb
- 3
Is it possible to charge a 7.4V 850mAh lipo battery on a 10V 4mA power source?
Inquiring minds want to know. Thanks everyone!
Macgyverasb said:Is it possible?
Yes, possible but only just. It will take a long time, and you may need a custom designed quite unique charging circuit.Macgyverasb said:Is it possible to charge a 7.4V 850mAh lipo battery on a 10V 4mA power source?
NascentOxygen said:quite unique charging circuit
I'm surprised to learn that, given that it sounds like such a narrow niche market. Can you point to an IC that can directly charge an 850 mAH cell while drawing less than 4 mA total?rbelli1 said:Most of the usual suspects (Analog Devices, Maxim, National, etc.) produce devices that will certainly work with that level of input.
Seems that the 8490s quiescent current is not going to leave anything for the battery.rbelli1 said:http://www.linear.com/product/LT8490.
This cycles rapidly to discharge the input capacitor then let's it recharge and repeat. It is designed for solar panels but I don't see why it could not be used for any high impedance power source.
BoB
Battery charging is the process of replenishing energy in a rechargeable battery by supplying an electrical current to it. This restores the battery's energy so it can be used again.
The different types of battery charging include trickle charging, fast charging, and smart charging. Trickle charging is a slow and continuous charging process, while fast charging delivers a high current to quickly charge the battery. Smart charging uses advanced technology to optimize the charging process for maximum efficiency and battery health.
The time it takes to charge a battery depends on the type and capacity of the battery, as well as the charging method being used. Trickle charging can take several hours, while fast charging can take anywhere from 15 minutes to an hour. Smart charging can take longer but is more efficient and better for the battery's lifespan.
Yes, overcharging a battery can damage it and reduce its lifespan. This is why it is important to use the correct charging method and monitor the battery's charging time. Smart charging technology can help prevent overcharging by automatically adjusting the charging rate.
Yes, there are some safety precautions to keep in mind when charging a battery. Make sure to use the appropriate charger for the specific type of battery. Do not overcharge the battery or leave it charging unattended. It is also important to keep the charging area well-ventilated and avoid exposing the battery to extreme temperatures.
