Understanding the Process: Jump Starting a Car Battery in Series or Parallel"
In summary: When connected in series the voltages of the batteries add up to give a greater "push" to the current (compare with the case when inserting batteries in electronic devices - flashlight, walkmans etc.). Since the electric systems of a car operates on 12 V this would not be a good idea. When they are connected in parallel the output voltage stays the same, but the total amount of current delivered into the load will be the sum of each supply (the parallel connections let's each supply add to the current finally reaching the load) - which is what is needed when the car is started - lots of current! Parallel connection.
pivoxa15
2,255
A motor car with a 'flat' battery can be started by connecting jumper leads from the battery to the leads of another car battery. To do this, the two positive terminals and the two negative terminals must be connected together.
1) Why is this?
2) Are the two batteries in series or are they parallel?
none
1) The dead battery has the positive and negative terminals at the same potential. So when a working battery connects its positive end to the positive end of a dead battery and negative to negative, a current will flow from positive to positive of dead battery. Current (using postive charge always, reverse for electrons) will flow from negative of dead battery to negative of good battery since the potental in the negative of dead battery is greater than potential of negative of good battery. Overall, this will mean higher potential at positive end of dead battery (because more charges are there now) and lower potential at negative end of dead battery (because charges which were there have migrated to the other good battery) meaning a restoration of the dead battery. However, this is done at the expense of the good battery as its PD is smaller as a result.
2) The two batteries are connected in series?
Sounds good.
No! The batteries are in parallel, not in series. A series connection would involve connecting the positive terminal of one battery to the negative terminal of another.
- Warren
Doesn't that depend on whether you see the dead battery as a power source or a drain? When dead, surely it acts like a resistor.
A "flat" battery is more complicated than a resistor. The simplest way to model a dying battery is as a constant source of emf with an increasing internal resistance. A voltmeter with huge internal resistance draws essentially no current, so if the voltage is measured with no other load on the battery it will still read the same voltage. A battery tester uses a "typical" load resistance to draw current from the battery while the terminal voltage is being measured. If the voltage reads low, it is because of the voltage drop across the internal resistance of the battery. For a car battery, the internal resistance is very low, on the order of a few milliohms. It takes a lot of current to drive the starter motor, so if the internal resistance rises the terminal voltage drops and the battery cannot drive the starter. This is why the lights dim when you crank the starter, even though they may still be bright otherwise.
A battery is not recharged by simply connecting it to another battery with the same emf. It has to be connected to a higher voltage source that will force a reverse current through the dying battery. Battery charges do this, usually with some control circuitry to regulate the reverse current. It is also done by the generator connected to the car's engine.
Jump starting a car is usually accomplished by using a running automobile with a good battery connected in parallel with the weak battery in a second auto to run the starter motor and get the second engine running. The jumpers can then be removed because the running engine drives the generator, which will then recharge the flat battery. Even if the second auto is not started, the generator of the running auto will provide the higher voltage needed to recharge the flat battery in the second auto, so after being connected for some time the flat battery will be sufficiently charged to start the car.
The batteries are definitely not connected in series. If they were, there would be a 24 volt emf in a circuit of very low resistance, and some very nasty things could happen.
No, it still acts (chemically) like a battery, though it does have some internal electrical resistance as well.
To charge a battery, you pass current through it in the "wrong" direction, into the +ve terminal and out of the -ve. If you pass more current through a fully discharged battery in the "normal" direction, you stand a good chance of wrecking it permanently - e.g. you may supply energy that causes irreversible chemical reactions, and/or damage its physical structure by overheating it.
In the "flat car battery" case, you connect a fully charged battery in parallel with the "flat one". You don't break the existing circuit (battery + ignition switch + starter motor) and connect the charged battery in series with those components.
DaveC426913 said:
Sounds good.
Hm. Is it too late to change my answer?
...connect the charged battery in series...? I thought it must be in parallel as everyone have been saying?
It's in parallel because car batteries is usually connected in parallel so to recharge it, the new battery must also be connected in parallel. But could you argue that the car battery is a block of parallel connected emfs. How about modelling it as a single large emf so you now have two emfs connected in series?
The "new" battery does not serve to recharge the "dead" battery in such a situation. It effectively "replaces" the dead battery as OlderDan explained. Since the dead battery will be at a slightly lower potential than the new battery the new battery will push some current through it in reverse, thereby starting to recharge it, but with most batteries this is a timely process and the dead battery will therefore act as an additional load on the new battery throughout the jumper start.
I do not really follow what most of you are saying. Maybe a picture of the circuit will clear things up. I've drawn one. I think there are 6 chemcial reactions going on with a total of 2V in each so a total of 12V for a car battery. Is my diagram correct? If not please correct me. I was thinking of representing the 6 car batteries as 1 dead battery. So you have 1 good battery and 1 dead battery which looks very much is connected in series. Have I made some fundalmental mistakes.
One car battery (dead or alive) will consist of six individual cells connected in series like this
1 battery:
o === |- === |- === |- === |- === |- === |- === o
o : pole connection on battery
|- : one chemical cell in the battery
=== : connections between components
| : positive side of a chemical cell
- : negative side of a cell
the left o will therefore be the high potential + pole of the battery
the right o will then be the negative pole of the battery
when a battery goes down one or more of its cells can become ineffective
Forget about the internal cells that make up a single 12V battery -- they're completely irrelevant. Just consider connecting one 12V battery in parallel with another, and connecting them to the rest of the car's circuitry (including its starter motor).
- Warren
Ah. Andrevh has an important point in post 10! The problem does not ask about RECHARGING the dead battery, it asks about STARTING the MOTOR.
The new battery WILL start the motor, whether or not it also charges the dead battery.
Thus, he is correct, the new battery is in PARALLEL with the dead one.
- Warren
Are my diagrams correct?
Are you suggesting the (second) diagram on the right is correct? If so are you suggesting it is connected in parallel? It looks like in series to me with the single block.
If you need more current than a single battery can supply.
How do you hook up additional batteries?
What happens if you connect the positive terminal of a battery to the negative terminal?
In the above question, does it make a difference if your battery is composed of multiple cells in series?
No.
See my attached diagram.
The circuit we are being asked about is BATTERY > MOTOR. The dead battery acts effectively like a resistor. It will charge, but you could replace the dead battery with a lightbulb and have effectively the same circuit.
If both those batteries were working, they would be in parallel - powering the motor.
I should defer to those more knowledgeable; this is just my understanding.
Dave, your diagram seem to make sense. I didn't factor in the motor. The battery's job is to start the motor working only isn't it? So if the battery in the car is dead, all you need to do is install a new battery in the circuit to start the motor up.
If you are going to recharge the dead battery, you wouldn't do it in the car, or else during the recharge the motor would be on and a lot of electricity is wasted into powering the motor. You would take the dead battery out of the car and connect it with the good battery in series. Like what I showed in my diagrams.
DaveC426913 has the right idea.
But , yes u are basicly just replacing the battery.
The existing one doesn't make much difference.
Err No. Definitly not. This is just wrong.
The dead battery will draw very little current from the new battery during the jumper start. So it acts as like large resistor in effect - like Dave says.
When you recharge a battery it is common practice to disconnect the leads to the car circuit. It is not connected to the electric components of the car at that stage (when the car is turned off no components is connected to it or draws current from it - except maybe the security system). But the main reason is to protect the alternator diodes which could be damaged by the recharger due to the large reverse voltage applied by it.
Normally not necessary.
If you are using a fast charger that's going to drive the terminal voltage above 15v then yes.
More for the other car electronics than alternator diodes, which are good for at least 50PIV.
However, this type of charge isn't particuarly good for the battery life expectancy.
This is the part that's a problem.
Doing this is likely to cause the battey to explode.
OK, now there's two ideas going on:
1] The problem as stated in the OP.
2] The method for jumping a battery in a car.
They're the same thing, but #1 exists merely as a analysis, while #2 has a goal, i.e. #2 has a why.
Note, as previously, that nowhere in the OP is there any mention of charging the dead battery. The problem at-hand is about starting the motor.
- You hook up the two batteries in parallel.
- The dead battery acts like a resistor.
- The live battery starts the motor. QED.
Jumping a battery in a car. This has to do with WHY you would do the above, and the subsequent steps.
- Hook up the two batteries in parallel.
- Do NOT disconnect the dead battery OR the starter motor.
- The live battery starts the starter motor (which then starts the engine). While technically, the live battery is ALSO charging the dead battery, it only does this in principle, it is insufficient.
- Now disconnect the live battery. The engine is now running with no battery power.
Now...
- The alternator is a device that uses the engine's power and creates electricity. It is also in the circuit with the motor/engine.
- With the engine running, you are using gas as a fuel to createelectricity. The alternator is now the power source in the circuit.
- The alternator now charges the dead battery, which is still in the circuit.
This is why, when you jumpstart a car, you cannot immediately turn the engine off - you still have a dead battery. You must drive it around so that the engine/alternator recharges the battery.
Causing the dead or live battery to explode? And why.
Note, as previously, that nowhere in the OP is there any mention of charging the dead battery. The problem at-hand is about starting the motor.The problem as stated in the OP.
- The live battery starts the motor. QED.Jumping a battery in a car. This has to do with WHY you would do the above, and the subsequent steps.
Now...
Does jumping a battery = recharging a battery? And when recharging in a car, we use the word jump?
So batteries in cars can be recharged simply by running the motor (which was intially started by an external battery). But I have seen car owners change batteries in late 90s cars Toyota Camry. Was it the case that no alternator was present?
There are some starnge methods of jump starting cars being quoted here.
If you jump start a car you do indeed effectively put a new battery in parallel with the old one. But you actually connect the positives together and the Earth of the jumping battery to the Earth of the vehicle being jumped, an engine mount or similar.
You connect positive and then negative in order to prevent sparks that may in extreemly rare cases ignite hydrogen liberated from the flat battery when you tried to start the car with it. I am very slip shod with this and have never blown my self up so I think it is a mathematical posibility rather than an actual one.
You then turn the starter motor using the jumping battery, not charge the dead battery. When the car is started the alternator will charge the battery in 30 minutes or so.
If jumping of a battery in another car you keep that car running with slightly elevated revs as thgis both increases the starting voltage and prevents you flattening the battery in the other car.
You don't disconnect the flat battery as this will wipe anything that requires permanent power like your Car Stereo key code.
You don't connect the batteries in series as when you started the car the lots of amps required to turn the engine would go through the dead battery, boil the dilectric fluid, liberating hydrogen and blowing acid all over the garage.
Ah. I always wondered how/why they exploded. So they boil!
OK, two things. Your pick:
1] I've always heard about jump-starting a car, not a battery.
2] Technically, you can say you are jumping the battery, though that's little to do with getting your car going. "Jumping" in electrical terms refers to bypassing a component. You might jump a resistor or some other component on a circuit board. You do this by bridging it with a wire, or "shorting" it. So, technically, you are jumpnig the battery, i.e. you are effectively removing it from the circuit by creating a new circuit that goes around it.
There is nothing wrong with replacing the battery. That accomplishes the same thing - a car with a fully charged battery.
If you jump-start a car with a battery that really is permanently dead, then you're driving on borrowed time. The next time you turn the car off you won't be able to restat it again. If you're clever, that will be in the parking lot at the nearest Canadian Tire (or equivalent), where you will pick up a new battery.
What's the difference between a permanently dead battery and a dead battery?
How could you tell?
A dead battery will have no charge but will hold a charge when recharged. A permanently dead battery will have something wrong with it such that it won't be rechargeable, perhaps all its fluid will have boiled off or there's a leak, or the electrodes are corroded.
As for how you could tell, well, batteries are designed to be fully self-contained, and I wouldn't recommend trying to open one up. I believe most these days have a tiny green light that goes out if the battery is dead-dead.
The green "eye" is a hydrometer equivalent.
It is supposed to measure the condition of the electrolyte.
Not particularly useful since they only put it in one cell.
Black indicates the one cell is discharged, not if the battery is still good.
There are 6 cells in a 12v auto battery.
If one of the other cells is shorted or otherwise defective there is no way for the single indicator to show this.
Auto battery testing is usually done by measuring the internal resistance which increases as lead erodes off the plates and settles to the bottom of the cells.
Requires equipment that can handle 100+ amps.
Cells also short out and this will show up as a decrese in terminal voltage. -2v for each shorted cell.
You can test this yourself with a voltmeter. Turn on headlights with engine off and measure voltage.
  • #31
Melt and arcover.
Had one of the old style open ones explode from a spark from an arcwelder I was using about 15 feet away.
Quite a big bang, I got hit hard enough by bits of the case to leave a couple bruises and needed a shower.
The acid might have made the skin a little pink but no serious burns.
  • #32
The Hydrogen gas released by a charging battery could be the source of an explosion. You need to be conscious of this release, but as mentioned up thread it seems to be a small chance.
When jump starting a car with a dead battery I do not start the car with the good battery. In the past I have seen diodes on the GOOD car get damaged. The problem would be the current draw of the starter, Diodes not not normally carry this current.
One good way to proceed is to connect the good car/battery to the dead car/battery then run the good car till the bad battery has enough charge to start the car. This is a bit slower but greatly reduces the chances of damage to either car.
  • #33
What are the differences between the two choices?
So the first alternative is to connect a good battery with dead battery and let the good charge the bad. The second alternative is to do that except turn on the engine of the car which contains the good battery. Does the second imply the dead battery is charged by the motor of the car? But the new and dead battery are still connected so wouldn't the new battery charge the dead one as well?
  • Mechanical Engineering
