Battery Questions: Answers to Common Questions
  • Thread starter Wagon Master
  • Tags
    Battery
In summary, the conversation discusses various topics related to automotive and deep cycle batteries. The first part clarifies the difference between a "12" volt automotive battery and a deep cycle battery in terms of voltage and design. The conversation then shifts to the possibility of creating a larger, more efficient battery by combining multiple batteries into one unit. However, there are concerns about safety and effectiveness from the experts in the conversation.
Wagon Master
Hey guys,
I'm new here, and I know just enough to be dangerous, so please bear with me when I ask stupid questions.
Perhaps like these.
1) If I understand correctly, a "12" volt automotive battery is made up of 6 cells, each providing 2.2 volts, thus supplying an actual total of 13.2 volts from a "12" volt battery. Is this right?
2) If I understand correctly, an automotive battery is designed to provide maximum amps for a minimum time (starting the car), at which point it is recharged. If completely drained and then recharged, it's life will be about 200 cycles. A deep cycle battery is designed to be cycled many 100's of times, at (I'd assume) some lesser amount of amps. If this is all correct, what is the difference in design?
As I said, I know just enough to be dangerous. For example, I always test car batteries by putting my tongue on them...:rolleyes:
You could save yourself the trouble and just try some of Turbo's salsa...
I think that an auto battery is referred to as '12 volt' simply because that's the system requirement. I don't know about deep-cycle batteries.
Welcome to the PF, Wagon Master. Here's an introductory article from wikipedia.org about car batteries, with links to other information sources:
http://en.wikipedia.org/wiki/Car_battery
Thanx berkeman,
The Wiki article pretty much answered my questions. Which leads to a follow up question:
My father has a solar system that uses 20(ish) deep cycle batteries for power storage. These are fairly expensive to replace when they need it, and take up a fair amount of space on a battery rack.
Why couldn't he and I get an oversized Rubbermaid container, weld some plastic seperator panels into it, and have our very own really big battery? It would be repairable, with the ability to swap bad plates for good, and be far more space efficient. We could micromanage the electrolyte content, and even build for different voltages (2.1 V per cell times how many cells do you want).
Any ideas on the build-our-own-battery question?
Sounds like an accident waiting to happen, not in my house.
How could you make it more space efficient then a modern auto battery? There is a lot of money being spend in battery research now. You will be in competition with teams of engineers with corporate level funding, all trying to make a better battery. The chances of a layman individual contributor making a break though in battery technology is remote. Meanwhile a large vat of acid setting around the house has little attraction for me.
I'm not looking to re-invent the battery, just the package. 20 current issue deep cycle batteries, with all the attendant shelving and cables, take up a lot of room are far less space efficient than what I propose. I'm not really keen on the acid in the house either, but out in a shed (where the current batteries are stored) is another story.
I'm just wondering if there are any obvious (to you guys who know such things) flaws in the idea of creating a physically larger battery than is currently for sale?
Thanks
I'm an electrical engineer, and I really, really doubt that your rack of deep-cycle batteries could be made more space efficient by a guy with a Rubbermaid vat, acid, and some metal plates. I agree with the others -- please do not try this. At best, it won't work; at worst, someone will get hurt.
Also, note that a shelf full of batteries wired in series creates a potential difference of some hundreds of volts. Such voltages can be deadly, and can vaporize dropped wrenches. The hazards are numerous.
That said, larger batteries do exist -- utility companies and commercial UPS systems use them, for example. They're probably pretty damned expensive, though.
- Warren
It seems a bit strange to me that the present arrangement is too 'bulky', but the bit about all of the 'attendant cables' might be the main problem. I'd be using flat-strap bus bars for the intra-battery connections, with the batteries physically stacked together like bricks. If that were to cause a thermal problem, they could be separated an inch or so with cooling fans blowing through the gaps. It should be a lot more compact than a shelving system.
Am I missing something?
Sounds good until the one on the bottom needs to be replaced :smile:. That's where a rack with about 4" of space above each battery comes in handy.
Gotcha.
I did actually think of that when making the suggestion, but dismissed it because I figured that maintenance-free (sealed) batteries wouldn't need to be accessed.
Still, the batteries could be stacked end-to-end, with bus bars, on slide-out racks similar to cabinet drawers and still be very compact. You could, for instance, have 5 batteries in one rack (connected with bars) with an identical rack beside it and 2 more on top. The rearmost batteries in each rack can be connected with plug/socket units. For maintenance, an entire rack could be pulled out on its rails (unplugging from the neighbours), then pushed back in when ready to go.
- Warren
Warren,
A motorcycle battery is no different than a car battery, just smaller. A group 24 battery is smaller than a group 78 battery. A marine battery is larger than all of them, still no different other than size. According to Wiki, a modern battery is really nothing more than a plastic box with some dividers in it, and acid poured over some metal plates. Commercial outfits (as you state) have batteries that are really no different than a car battery, just many times the size.
I'm not trying to be arguementative; it's just that 99% of the population will tell me it can't be done, but when pressed for a reason, will only say "beacause nobody has done it". I came to the Physics Forums to find out why it can't be done.
You are absolutely incorrect.
Marine batteries are absolutely different from motorcycle batteries, in more ways than simply the physical size. Marine batteries have much larger capacity, and can deliver much greater currents. (They have thicker plates and thus smaller series resistance.)
You can try the acid-vat technique if you want. I'm not saying it can't be done -- I'm just saying it probably won't work as well as commercially-made batteries and will subject your lives and property to significantly greater risk. The risk/reward ratio on this is just way too high to be a sensible project. Do it if you want, but don't say I didn't warn you.
- Warren
- Warren
I don't know about absolutely incorrect: The motorcycle to car battery comparison seemed good, and while deep cycle batteries have a different output (lower over a longer period of time), their construction is basically the same.
The advantages of the acid-vat over a commercial battery are cost (I'd assume: I haven't actually priced anything yet, because until today I wasn't sure it could be done.) and user servicability. My father is 80 miles of mud from the nearest place to get a commercial battery.
As for the warning, thank you. And not to worry; I would never blame someone else for not warning me about a choice I made as an adult.
First, check out Rubbermaid's acid resistance. You could end up with a big puddle of molten plastic.
At the very least, make sure that you provide a proper ventilation system. Your homemade battery is pretty much sure to exhale deadly fumes.
Rubbermaid wouldn't be the actual container; I just used it for an example. As for the deadly fumes, agreed. Though somehow many of today's batteries are completely sealed...:confused:
how'd i do on my first try?
Wagon Master said:
Warren,
It can be done. Your idea will work. Though, as several have pointed out, it will be dangerous. And I would add that it may not even be cost effective. Now it's been 30 years since I've studied industrial sized lead acid batteries so some of my opinion may be outdated.
Lead acid batteries, as I recall, use something called sponge lead. Sponge lead increases the surface area of the plates giving you a higher capacity. Replacing sponge lead with simple lead plates would require that you use more plates to get the same capacity. Now if the plates are too thin then you run into the problem of plate disintegration. As you know, when you discharge a lead acid battery, the lead leaves the plate and enters the solution. As I recall, this was the primary source of battery failure, ie. entire chunks of the sponge lead crumbling off of the plates due to uneven lead removal and redeposition.
I believe this is why you don't want to discharge lead acid batteries past a certain point. My recommendation would be to double or triple the number of batteries in your system to prolong their life. If you still want big batteries, I would research the type they use in submarines. Each cell weighs about a ton, and of course you would require 6, so it might be a bit spendy.
I could go on all day about this, so I'll end with a little autobio stuff since this is my first post and this might explain why I started on this thread:
I have 4 solar panels. Mainly I use them in my boats as an auxiliary power source. I live in a forest setting and have been too chicken to climb up the 60 or so feet to get them into some decent sunlight. I had 2 panels set up on the south side of my house last winter and could not get enough solar energy to keep my battery charged to run a 1 watt string of x-mas lights.
I guess I have just the opposite problem that you do. Even with all 4 panels in place, I wouldn't even keep a 12 volt garden battery charged.
Has anyone here at the forum done the math on the difference between compressed air energy vs. battery storage capacity as a function of cost/volume/efficiency/etc.? I know they run buses in Brazil using compressed air. Just thought it might be a viable alternative.
Welcome to PF, OMCheeto.
That was a beautiful first post. Very informative, without being condescending. That indicates to me that you will be a very valuable asset to these forums.
In fact, I learned a lot from that. I never realized that the lead plates were sponged. It makes a lot of sense, but I never heard about it before.
Wagon Master said:
Hey guys,
... snip...
Just as a reminder of your own words at the start of this thread. I hope that you will begin to understand that there is a significant amount of engineering invested in a modern battery.
If you must build a battery, please start small.
Thank you. But before you get too comfortable believing what I say, let me just say that there is an error in my first post. I've been researching compressed air for the last hour and have decided that my brain has somehow short-circuited. I can find no reference to air powered vehicles in Brasil anywhere on the net. Perhaps it was just a dream I had one night, or perhaps I read it in a http://portland.indymedia.org/en/2007/06/360403.shtml".
Not to worry, lad. I think that you've just mixed up your continents. We have a prior Engineering thread about air cars, but I think that they're in India or Pakistan. As for their efficiency, I have no clue.
Compressed-air vehicles are definitely being investigated -- but, as far as I know, none are being mass-produced yet.
- Warren
back to something I do/did know something about
Wagon Master said:
...These are fairly expensive to replace when they need it, and take up a fair amount of space on a battery rack.
One thing you have to remember is the different environments that your batteries and automotive batteries live in. Car batteries are constantly being shaken about while your batteries are just sitting there. One of the problems with lead acid batteries is http://www.progressivedyn.com/battery_basics.html" . This is where the denser fluid sits at the bottom and vice versa. Adding a bubbler system to your batteries can prevent this from happening.
And I did say it was 30 years didn't I? I completely forgot about this:
http://www.boatelectric.com/sulfation.htm"
Lead sulfate (PbSO4) is created at both the positive and negative electrode plates during a discharge. In principle, during the charging period, 100% of the lead sulfate transforms to the positive plate (lead dioxide), the negative plate (lead) and sulfuric acid. However, in real life, when PbSO4 (lead sulfate) is left in the battery for a period of time, it crystallizes and becomes a hard sulfate that coats the surface of the electrode plates. This phenomenon is called sulfation. Because hard lead sulfate is a non-conductive material, when it coats the electrode plates, it causes a reduction in the area needed for the electro-chemical reactions. It also reduces the batteries' active materials needed to maintain a high capacity.
I've had car batteries that have lasted up to 10 years. But I've killed brand new batteries in just a fraction of that time by letting them just sit around the house.
Along those lines, having a battery that I can interact with means I can pull the plates and descale them. When a plate wears out, it can be replaced without tossing the whole battery. Venting should be easy since hyrogen gas is light.
Other than the nasty possiblity of explosion (and what is life without adventure?), I don't see a down side. Granted I haven't checked the costs of plate yet...
One thing I would be careful of in a homemade battery is that the connections around the battery and plates are 'bullet proof'. I've seen several batteries explode and it is usually from arcing at connections after the battery has received a healthy charge. Hydrogen gas is the culprit. Make connections that are solid.
I'm not good at chemistry, so I'm not sure what is involved with descaling a plate. You might have to melt them down and create new plates.
As for suppliers? You might try http://www.globalspec.com" as a starting point.
Point taken. I recall that there is an acid resistant coating used to moisture-proof electrical connections, and I'll look into that. Additionally, I had intended to store the battery away from the house, and in a pit.
I wouldn't go as far as digging a pit. The only explosion hazard from these batteries is either from internal pressure or hydrogen build up. I would recommend making sure the batteries have fail-safe vents.
http://www.ccohs.ca/oshanswers/safety_haz/forklift/batteries.html#_1_5
Why is there a danger of exploding batteries?
The charging of lead-acid batteries can be hazardous. When batteries are being recharged, they generate hydrogen gas that is explosive in certain concentrations in air (the flammability or explosive limits are 4.1% to 72% hydrogen in air). The spark-retarding vents help slow the rate of release of hydrogen, but the escaping hydrogen may form an explosive atmosphere around the battery if ventilation is poor. The ventilation system should be designed to provide an adequate amount of fresh air for the number of batteries being charged. This is essential to prevent an explosion.
There are some more exploding battery stories at the following site. All appear to be caused by either short circuiting or lack of ventilation during charging:
http://www.instructables.com/id/How-to-solder-with-an-AA-battery-and-a-car-battery/?comments=all
i had a frozen car battery explode at arms length from me while i was trying to charge it.
i lost a tooth and a good percentage of my hearing.
car batteries have my undying respect.
be carefull
Just remember that batteries can short circuit internally. So every precaution taken on your part may be negated by the battery itself.
hmmmm... On second thought, maybe you should dig a pit.
1) How long do batteries last?
The lifespan of a battery depends on several factors such as the type of battery, usage, and storage conditions. Generally, disposable batteries can last anywhere from 2-10 years, while rechargeable batteries can last for 2-7 years.
2) Can I mix different types of batteries?
No, it is not recommended to mix different types of batteries in a device. Different types of batteries have different voltage and chemical compositions, which can cause damage to the device or the batteries themselves.
3) How do I dispose of old batteries?
It is important to dispose of old batteries properly to prevent harm to the environment. Many electronics stores and recycling centers have designated drop-off locations for batteries. You can also check your local government's regulations on battery disposal.
4) What is the best way to store batteries?
Batteries should be stored in a cool, dry place at room temperature. Avoid storing them in extreme temperatures or in direct sunlight. It is also recommended to store batteries in their original packaging or in a battery organizer to prevent them from coming into contact with metal objects.
5) Can I overcharge my rechargeable batteries?
Yes, overcharging rechargeable batteries can cause damage and shorten their lifespan. It is important to follow the manufacturer's instructions and use a suitable charger for your batteries to prevent overcharging.
  • Electrical Engineering
16K
