Bead Entering Capacitor
  1. Mar 6, 2014 #1
    A small bead of mass m= 34 g and charge of Q=140 mC has a velocity (all in the horizontal direction) of 7 m/s as it enters the gap of a parallel plate capacitor, initially traveling parallel to the plates. The plates are separated by 4 mm. If the bead enters the capacitor 2 mm above the bottom plate, and leaves the capacitor 2 mm above the bottom plate, calculate the potential difference between the two plates.
    m = 0.034kg
    Q = 0.140 C
    vx=7m/s
    y = 0
    d = 0.004m
    2. Relevant equations
    ma = Fg + qE
    V = Ed
    3. The attempt at a solution
    I was more or less wondering how to conceptually think about this problem. Since the bead leaves the plates at the exact same height it was initially, does that mean that the force of gravity is equal to the electric force? Therefore I can equate
    mg = qE
    After, I can just sub in V = Ed into the force equation and solve for potential difference.
    But with this solution, does that mean that the initial speed is irrelevant?
    Thanks
  3. Mar 6, 2014 #2
    TSny
    2017 Award
    Hi Peetah.
    Your analysis looks correct to me. The speed is irrelevant.
  4. Mar 7, 2014 #3
    BvU
    2017 Award
    Something strange here. How can a 4 mm bead weigh 34 gram ? And how can it enter 2 mm above the bottom plate and still exit unscathed ? Isn't the top plate smack in the trajectory ?
  5. Mar 7, 2014 #4
    Its not a 4mm bead, thats the separation distance between the two plates. Bead is point charge
  6. Mar 7, 2014 #5
    BvU
    2017 Award
    I see. And what is its density, approximately, if it is smaller than 4 mm and still weighs 34 gram ?
    A bead of r=1 mm has capacitance 9 pF. 140 mC on that gives a potential of a TeraVolt. Lightning!
    But: you are not responsible for the credibility of the exercise. And:
    to me too ! Kudos!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Bead Entering Capacitor
  1. Bead Problem (Replies: 1)
  2. A bead on loop (Replies: 10)
  3. Rotating bead (Replies: 23)
  4. Ring and beads (Replies: 2)
Loading...
