Bead on a rotating hoop
  • Thread starter Loro
Loro
80
We have a bead confined on a circular hoop. The hoop is rotating around an axis tangential to it. Suppose the bead is intially at the point, farthest away from the axis, and has got some intial velocity.
I have a question - in the frame of the hoop, there is a Coriolis force perpendicular to the plane of the hoop, and a balancing reaction force. Then there is a centrifugal force, which has got a component normal to the hoop.
How big is the force from the hoop, balancing this one? Is it of the same magnitude as this normal component, or is it bigger so that it provides a net centripetal force associated with the motion of the bead around the hoop?
Answers and Replies
tiny-tim
25,836
255
Hi Loro! :smile:
If I'm understanding it correctly, the initial relative velocity (which is tangential) is parallel to the axis of rotation, so the initial Coriolis force is zero. :confused:
Loro
80
Yes, that's what I mean. Sorry that I didn't make a picture.
tiny-tim
25,836
255
I'm not sure what you're asking.
In the frame of the hoop, there's a centrifugal force away from the axis, there's a Coriolis force "vertically" out of the plane of the hoop, there's a centripetal acceleration towards the centre of the hoop, and there's a tangential acceleration …
when you put them all together, what equations did you get? :smile:
Loro
80
So if I were to compute the reaction forces of the hoop, there would be:
- one "vertically" out - balancing the Coriolis force
- and one towards the centre of the hoop
But would the latter be equal in magnitude to the component of the centrifugal force, normal to the loop? Or would it be that, + the centripetal force?
tiny-tim
25,836
255
Yes, the reaction force (for a frictionless hoop) must be perpendicular to the tangent, so it will have a "vertical" component and a radial component.
Ftotal = ma …
Ftotal is the centrifugal force plus the reaction force
a is the centripetal acceleration plus the tangential acceleration
So, in the radial direction, the component of the centrifugal force plus the component of the reaction force must equal the centripetal acceleration times the mass.
Loro
80
Thanks, that answers my question! :)
Suggested for: Bead on a rotating hoop
  • Last Post
  • Last Post
13K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
