Beam bending strain field
  • Thread starter lewis198
lewis198
96
If I have a wide beam, parallel to the x axis, with its COM at the origin, then I want it to curve about the y axis, what would the elements of the strain tensor be?
I have come to the conlusion that the beam would, for example,contract above x-axis and expand below it. But I don't know how to describe strain relative to the y and z axes, and then how to translate this knowledge to the strain tensor.
Thanks for your time.
Answers and Replies
afreiden
114
"wide beam" to me sounds like a shell.
Reissner-Mindlin shell theory is what is used in Finite Element Analysis. They neglect the higher order terms but there is a lot of information on the subject.
If you are more interested in analytical theory that is analogous to standard beam theory, then I believe "Kirchhoff-Love" would be what you are looking for.
Hope that helps,
Studiot
5,441
Hello Lewis, you really need to supply more information.
Wide beam? : What sort of wide beam?
Wide flanged I beams are available for increased bending resistance and their properties are tabulated.
There are code requirements and specifications for wide RC beams.
I am going to assume a simple homogeneous rectangular wide beam of height h in the y direction and breadth b in the z direction.
Yes you need also to specify the z direction - wide beams are 3 dimensional.
A beam is considered wide when
b >> h say 5 times or more.
Under these conditions the material is not free to expand or contract in the lateral z direction under bending along the x direction about the y direction. (note I said direction not axis)
In particular εz ≈ 0 at z=0 so
[tex]{\varepsilon _z} = \frac{1}{E}[{\sigma _z} - \nu \left( {{\sigma _x} + {\sigma _y}} \right) \approx 0[/tex]
Since h is small σy ≈ 0 So
[tex]{\sigma _z} = \nu {\sigma _{{x_{z = 0}}}}[/tex]
Thus
[tex]{\varepsilon _x} = \frac{{1 - {\nu ^2}}}{E}{\sigma _x} = \frac{{1 - {\nu ^2}}}{{E{I_z}}}{M_z}y[/tex]
In general the strain is reduced by a factor of [itex]{1 - {\nu ^2}}[/itex]
Edit
So you can see that the change is the insertion a modifying constant into your strain tensor, I will leave you to do this since you haven't provided any notation.
You need to be careful here since my strain is engineering strain, not tensor strain, which is a factor of 1/2 different.
You should also note that the sideways distribution may also depend upon the support conditions.
Suggested for: Beam bending strain field
  • Last Post
