Beam bending
  • Thread starter adsaw
I'm looking to see if a flexible beam I am using right now can be flexed further, currently it goes to around 25 degrees and I want to see if I can bend it to around 50 degrees without permanent deformation. Looking to do a back of the envelope calc to check this, what equation should I use, and what material stress should I compare this to? The beam is attached to blocks at the top and bottom and these two blocks are connected by a cable that can be retracted to create a moment and bend the beam:
| block|
| b | |
| ea| | <- cable
| m| |
| block |
Answers and Replies
711
If the beam is rotated through 25 deg already, you are way passed the limits of linear elastic beam theory, which usually means hand calcs are out the window.
minger
agreed
Related Threads on Beam bending
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
