Beam deflection equation
  1. Mar 31, 2015 #1
    I have A beam of 1.2 m long, supports at 0m and 0.8 m. forces of 10 N at 0.4 m and 5N at 1.2 m I need to find the deflection equation for this situation. Can someone have a look and see if they can come up with the equation. As I have tried but my results do not match what I am expecting
  3. Mar 31, 2015 #2
    Staff Emeritus
    Why don't you post your calculations? You may have made some mistakes in calculating deflections for this beam.
  4. Mar 31, 2015 #3
    I split the beam into 3 sections and found the moments acting at each section so section on 2.5 x second section -7.5x and the last section 5x I then integrated twice for each section and got 5/12x^3 +c1x + c2
    5/4x^3 +c3x +c4 and 5/6x^3 + c5x + c6 all equal to yEI. Does what I have done so far seem right to you because all I did next was find the constants and if this part isn't right then if my constants are wrong it won't matter as it's all wrong
  5. Mar 31, 2015 #4
    Staff Emeritus
    You have found some of the parts of the moment expression, but these parts act over limited portions of the beam.
    For instance, starting at the first support, M(x) = 2.5 x, for 0 ≤ x ≤ 0.4 m
    Similarly, the next part, M(x) = -7.5 x for 0.4 < x ≤ 0.8 m
    Finally, M(x) = 5 x for 0.8 < x ≤ 1.2 m
    You've got to write the bending moment function is such a way that all of the segments of the bending moment curve are treated together. This is difficult to do with regular algebra, but there are special ways to construct a bending moment function in a piece-wise manner. McCauley's method is one such procedure:
    You've wound up with too many constants of integration. When you integrate the moment equation to find the slope, you'll generate one constant of integration. When you integrate the slope equation to find the deflection, you'll generate another constant of integration as follows:
    M(x) = bending moment as a function of position x
    Θ(x) = slope as a function of position x
    y(x) = deflection as a function of position x
    Θ(x) = ∫ M(x) dx = Θ(x) + C1
    y(x) = ∫ Θ(x) dx = ∫ [Θ(x) + C1] dx = ∫∫ M(x) dx dx + C1 * x + C2
    The boundary conditions for this beam are that the deflection = 0 at the two supports, so you can have at most two constants of integration.
    You're on the right track. You just have to make some adjustments in how you construct the bending moment function and then integrate it.
  6. Apr 1, 2015 #5
    Thank you i will give it another go
  7. Apr 2, 2015 #6
    Thank managed to get the answer thanks to yoir help
Similar Threads - Beam deflection equation Date
Deriving Strain in Cantilever Beam with Known Deflection Jun 14, 2016
Beam Deflection Apr 3, 2016
Method to calculate beam deflection Feb 7, 2016
Beam deflection integration Jan 7, 2016
Beam Deflection Nov 26, 2015
