Beam-powered propulsion - keeping the beam focused
In summary, the conversation discusses the challenges of using beam-powered propulsion for interstellar travel, with a focus on the beam divergence problem and the potential use of multiple lasers or a single, tightly collimated laser. Theoretical calculations and practical considerations for achieving a small laser spot size over long distances are also discussed. The conversation also touches on the advantages and disadvantages of using on-board beam sources versus passive systems, and the potential for using light sail propulsion designs for breaking maneuvers at the destination. The conversation raises questions about the efficiency of lasers and the potential use of lower frequencies for more efficient sources.
  • #71
GTOM said:
It might could be used to power a lunar colony, without take a nuclear reactor there.
No, like chemical boosters, the beam system would be necessarily be designed to deliver very high bursts of power for a few minutes, not supply continuous power.
  • #72
Valid point. Still if it could power Earth-Moon vessels for example, than it could be frequently used.
  • #73
mfb said:
A smaller sail leads to a higher acceleration.
I puzzled over this but I have to assume that you are assuming the proportions would need to be the same so area : mass = l2:l3
But why would that be necessary? You see, I cannot see how you can ever get over the spillage with a sail of just a few cm3 area. Surely a sail area that's comparable with the beam area has to get most momentum transfer ( = acceleration). The only reason that small sail = higher acceleration might be that mechanics don't scale as you'd think and small structures are stronger for a given shape. But the pressure over a large sail would / could be fairly uniform so stresses would still be low. This hasn't been justified in anything I have read.
  • #74
mheslep said:
A similar comment could be made about the current chemical boosters and their mega-Newton thrust.
A different comparison. The cost of a rocket is much less than a once in a lifetime telescope. The 30m telescope has a budget of £$1200M so bigger would be considerably more (third power law perhaps) and a rocket launch is upward of £$100M (figures trawled from all over) If the telescope were doing this job in its spare time then things would be different as it's highly re-usable.
Likes mheslep
  • #75
A smaller sail means you can start with a more focused beam - a higher intensity. At the same mass per area ratio (=most of the mass is the sail), this leads to a higher acceleration.
You probably want the beam to be very uniform over the sail area to have a uniform acceleration. Which means the sail has to be smaller than the total beam width.
It is not a once in a lifetime telescope if you use it for thousands of small spacecraft , and use it as regular telescope.
  • #76
mfb said:
We can easily aim at it. Aiming does not get notably harder with distance, as you are diffraction-limited anyway: The necessary angular accuracy does not increase. And it is within the capabilities of current telescopes.
I might be misunderstanding something still. Let's say the spacecraft is 5 light-minutes away from the telescope/laser. You might be able to see it, but you won't see it at its current location. You'll see where it was 5 minutes ago, right? You can't know with certainty what its current location is, so if you want to aim a laser at it, you have to predict where it will be with great accuracy. Maybe it's possible to do that; it just seems outrageously difficult.
  • #77
If it don't make fast random movements, aiming will be still pretty accurate.
  • #78
Which is why I asked, further up, about other uses for such a telescope. Unfortunately, the word "telescope" is not really accurate because the transmitter would not be a good receiving system without serious modifications. I can't imagine it could be operated with a simple TX/RX switch. The use as a cargo propellor to the Moon would make sense, though.
But I still can't see the advantage of using such small craft when the beam could not be focussed on just one sail. Why not, at least, fill the beam with a single sail? One single craft would be much more use than many smaller ones (there can be no argument about that, surely). I can understand how a short sharp burst of acceleration makes sense, due to beam spreading at a great distance but spillage around a small sail would mean a huge wastage of hard-won propulsive energy. The Numbers Game is very relevant here and I haven't seen any actual numbers to dispel my intuitive objections. The project could be based on "We want to do it this way", and it wouldn't be the first such project.
Comms would be needlessly complicated in a case like that. Each craft would need its own channel and a dedicated receiver because of the necessary low bandwidth and the very long duration of a useful signal.
  • #79
How can you be sure that there would be no perturbations from, as yet unknown, sources. Just because the star appears at a fixed place in the sky, doesn't tell you about mechanical forces that could be operating way out there and a very tiny disturbance (a large, undiscovered Kuyper Belt object coming close, for instance) could deflect the craft. Open loop (ballistic) operation is a very risky way to go, imho. We have absolutely no way of being sure about this.
  • #80
@sophiecentaur: Please read the proposal of the Breakthrough Starshot project. You keep proposing things that are completely impractical, things discussed in detail (why they don't work) by the Breakthrough project.
The spacecraft is fast. A near miss at Pluto would alter the velocity by something like 5 cm/s, or 30,000 km over 20 years. Completely negligible.
The probability of such a near miss (or impact) for a random object at a random location in the sky at the distance of Pluto is less than 10-14. It is even smaller for objects further out. Negligible as well.
You could check the numbers before you invent issues that do not exist.
At the time it is 5 light minutes away, the laser won't be focused well any more and the acceleration (if present at all) is negligible.
The spacecraft has to have some control over its orientation in order to transmit data back to Earth once it reaches its destination, but that has to work with regular sunlight only, not in the intense acceleration phase.
  • #81
It might have been helpful to post a link to the document if you have found it already. Pretty much all I have found is Pop Science with generalisations. I have seen an animation which shows a big array of Hollywood / James Bond style microwave dishes, which rather put me off reading much further. There are numbers quoted, such as that the nano craft could get to Mars in 2m. What could it do when it got there, apart from to keep on going. Likewise for Pluto etc. That sort of popular blurb proves nothing either way but it worries me that the drivers of the project are happy for it to go out with the publicity material. I guess they want backers and don't expect many potential backers to have much of an idea about the practicalities.
Meanwhile, if you could let me have a link to the large amount of information you are able to draw on, I should be very grateful.
Likewise, I would be grateful for some basics for working that out without starting from scratch. Or you could just show your workings?
  • #82
I found it when the announcement was new, and read it, but didn't save the link. I don't think it is my task to find it again.
They have enough funding from billionaires to study the concept in more detail.
Going to Mars in 2 minutes (?) won't work, not even light is that fast.
Standard orbital mechanics, with some rough approximations. Pluto has a surface gravitational acceleration of 0.6 m/s2 and a radius of 1200 km. The spacecraft will fly in a nearly straight line. As conservative estimate (leading to a larger deflection), assume the surface gravitational acceleration acts as perpendicular force over 5000 km of the spacecraft trajectory. At 20% the speed of light, or 60,000 km/s, that gives an acceleration over 1/12 s, for a speed change of 5 cm/s. Over 20 years this leads to a deflection of 30000 km.
The fraction of solid angle Pluto occupies in the sky is pi (radius of pluto)^2 / (4 pi (distance to pluto)^2).
Basic high school physics.
  • #83
You told me I should read it so it is the least you could do for me. :wink:
You are right - but I got it from one of those easily losable Google hits about eat topic.
Thanks.
I was also considering gas or dust clouds but I guess, if the star group is easily visible, there can't be much in the way.
  • #84
Too bad i can't found the comments of a phys.org article, but there was a discussion about the focusation problems of high-powered lasers, due to amplification process (multi mode lasers) or heat stress of lenses/mirrors or something like that.
Although in that case the laser equipment dotn have to be compact unlike a militaty application, so there can be a forest of single mode low powered lasers.
  • Science Fiction and Fantasy Media
  • Mechanical Engineering
  • Quantum Physics
