Homework Help: Bearing load beam equation
  1. Aug 12, 2013 #1
    Need to know the bearing load for a linear slide i'm working on, two spaced bearings with an extended load off the end of the slide.
    2. Relevant equations
    What equation do I need to apply? What examples are out there?
    3. The attempt at a solution
  3. Aug 12, 2013 #2
    SteamKing
    Staff Emeritus
    You need to apply the equations of static equilibrium to determine R1 and R2.
  4. Aug 12, 2013 #3
    I'm still not sure how to apply, I can't find any relevant examples. The two distances are 1.5m and 1m, bearing spread and mass extended.
  5. Aug 12, 2013 #4
    R1 = 1/2.5*(30*1) = 12kg
    R2 = 1/2.5*((30*2.5)+(30*1)) = 42kg
    This is how I've done it, if anyone can give me some guidance that'd be great.
  6. Aug 12, 2013 #5
    Use equilibrium equations
    Lets assume both reactions (R1, R2) are facing upwards.
    Now we do the sum of forces in the Y direction=0, where upwards is positive.
    So, Sum of Fy=0: R1 + R2 - 30=0
    Now lets take the sum of the moments at point 1 equal to zero, where anti-clockwise is positive.
    So, Sum of M1=0: (1.5)(R2) -(2.5)(30)= 0
    (1.5)(R2)=75
    R2= 75/1.5
    R2=50kg
    Substituting in the 1st equation:
    R1 + 50 -30 =0
    R1 +20=0
    R1= -20kg
    So your reactions R1 and R2 are -20kg, 50kg respectively.
  7. Aug 13, 2013 #6
    Thanks I understand now, appreciate your help.
Have something to add?
Draft saved Draft deleted
