malek340
- 34
I'm currently finding a bearing or bushings that can work underwater without a housing with minimal rust. Do anyone have an idea if it can? If there is, pls give me the details of the bearings or bushings?
Bearings and bushings are mechanical components that are used to reduce friction and support rotating or sliding parts. They are commonly used in underwater applications to allow for smooth movement between two surfaces, without the need for a protective housing.
Some common materials used for bearings and bushings in underwater applications include stainless steel, bronze, and plastic. These materials are corrosion-resistant and can withstand the harsh conditions found in underwater environments.
Bearings and bushings for underwater use without housing are designed to be self-lubricating and able to operate in a submerged environment. They are typically designed with grooves, channels, or pockets to hold lubricant that helps reduce friction and prevent corrosion.
When selecting bearings and bushings for underwater use without housing, it is important to consider factors such as operating depth, temperature, pressure, and load capacity. It is also important to choose materials that are compatible with the surrounding environment and any potential contaminants.
Maintenance requirements for bearings and bushings for underwater use without housing will vary depending on the specific application and operating conditions. However, regular inspection and cleaning may be necessary to ensure proper functioning and prevent corrosion. It is important to follow any manufacturer recommendations for maintenance and replace worn components as needed.
