Beauty of old electrical and measuring things, etc.
In summary, the conversation revolved around an individual's passion for collecting and restoring old devices, particularly electrical components from the early 1900s. They shared photos of their collection, which included vintage bulbs, switches, and transformers, and discussed the craftsmanship and attention to detail of these items. The conversation also touched on the nostalgia and sentimental value of preserving and working with old technology. The individual credited their interest in old devices to a scrap collector who allowed them to explore his collection as a child.
  • #281
I'm just now getting around to restoring this Universal Radio.
I doubt that it's power plug would get a Underwriters Laboratories endorsement.
What I really find interesting is it's name plate; ... ONLY FOR RADIO AMATEUR, EXPERIMENTAL AND BROADCAST RECEPTION.
Likes collinsmark and jim hardy
  • #282
dlgoff said:
Hence the name, knob and tube wiring. I haven't acquired any tubes however.
You mean these things in my "ceiling"? They are still where they were installed although I have no clue how many decades since they were used. It was a bar in the 1930's.
Likes dlgoff
  • #283
What tubes does it use ?
  • #284
View attachment 223505 View attachment 223506
According to the Wikipedia page Knob-and-tube wiring, they were
in common use in North America from about 1880 to the 1930s.
Since that post I've acquired a couple of those "tubes".
  • #285
Except for one (a 6F6 GT which may have been a replacement tube?), they're all metal tubes.
Edit: @jim hardy, oops. There's another glass tube. The magic eye vacuum tube (6U5, 6G5).
Likes jim hardy
  • #286
Ahhh Octals ? :Local junkshop had a bushel of #30's. I'll see what else is there next week. old jim.
Likes dlgoff
  • #287
Thanks Jim. I'll post a list of these tubes here. The last time (many years now) I powered it up, it received just fine.
Ahhh Octals ?
The 6U5,6G5 has 6 pins.
  • #288
Great collection!
No slide rule or adding machine to top it off?
No TKD breakage either! Kids are kids.
  • #290
Nice collection. I have a couple of decitrig loglog bamboo slide rules and a pocket circular Concise slide rule with an embedded periodic table and other scientific constants insert. I also have an addiator, a handheld mechanical adder/subtractor that fascinated me as a kid.
  • #291
Photos?
Likes jim hardy
  • #292
Here's a list. Any or all would be welcomed. Thanks Jim.
Metal Shelled Tubes
6F6 - was probably a metal shelled tube originally.
6A8
6F5
6G6
6K7
5Z4
  • #293
That's awesome! You're probably a lot older than me, but I love that old aesthetic too :)
Likes dlgoff
  • #294
I finally got around to cleaning up the antenna for the Narco Superhomer VHT-3 navigation receiver. Here's how it looked initially:
Here it is with new paint:
I mounted it on a box so it could be mounted in place of the one I built. And like the old one, it has the Physics Forums logo that hopefully @Greg Bernhardt will like.
I mounted the antenna and just finished testing it with the Superhomer receiver. All functions tested okay. It's dark out now so I'll add a mounted picture later.
Likes Borg, collinsmark, jim hardy and 3 others
  • #295
How does it work navigation wise? Were there fixed transmitting stations and triangulation methods to determine your location? Or was that done by receiver magic?
  • #296
dlgoff said:
I could send you one of these. :biggrin:
I used to have a camera like the one on the left. It had been my parent's. I even used it when I was first into photography back in the late '70s. The negatives were large enough that you could produce a good print just using the contact method, and without needing a enlarger. I do still have my folk's Bell & Howell movie camera from the late '50s, still in working condition.
  • #297
It was my parent's camera as well. I have a lot of the pictures they took with it.
Likes jim hardy
  • #298
Navigation is done by the VHF omni directional radio range (VOR) technique. From the Wikipedia page:
A VOR ground station sends out an omnidirectional master signal, and a highly directional second signal is propagated by a phased antenna array and rotates clockwise in space 30 times a second. This signal is timed so that its phase (compared to the master) varies as the secondary signal rotates, and this phase difference is the same as the angular direction of the 'spinning' signal, (so that when the signal is being sent 90 degrees clockwise from north, the signal is 90 degrees out of phase with the master). By comparing the phase of the secondary signal with the master, the angle (bearing) to the aircraft from the station can be determined. ...
Likes jim hardy
  • #299
dlgoff said:
... I'll add a mounted picture later.
It looks good up in the air.
Likes sparkie and jim hardy
  • #300
The basic system has been explained. For the pilot, It is used this way: you tune your VOR receiver to the station you are using to navigate by. Then you adjust your VOR to the heading you want with respect to the station. A indicator will tell you whether you are flying to or away from the station (it also informs you if you are within range for the signal). A needle will deflect either right or left, which tells you what direction you need to fly to get on the wanted heading with respect to the station. You then just "Fly the needle"(Keep the needle centered ) to fly to or from the VOR station.
Likes dlgoff
  • #301
Some things I want saved for the for the future are geranium diodes and mylar variable capacitors, a small verity of tubes, old tube televisions in prestine condition, old solid state black and white televisions with air gap tuning variable capasitors in clean working condition, a few 1960s table top radios with the old style carbon comp resistors and ferite antennas, XT computers with 5-1/4 fdds, the works on that one, Mac se30's that still work with software, and dip IC's. Oh and quality VOMs.
I hope somebody keeps a warehouse full of this stuff.
Edit: don't forget the old tape decks and VCRs.
Likes jim hardy
  • #302
Chris Riccard said:
geranium diodes
Good luck finding geranium diodes. The geraniums tend to wilt in just a few weeks.
You'll have better luck finding germanium diodes.
Likes davenn, Fisherman199, DrClaude and 4 others
  • #303
The geranium joke reminded of the time a woman came into the store looking for self abasive tape, you know the kind that’s sticky on both sides.
Likes davenn and dlgoff
  • #304
And don't forget to empty the grid leak drip pans...
  • #305
I'm doing a pump-down with my "new" old Welch 1402 vacuum pump. It's doing a beautiful job.
Likes davenn, OmCheeto and jim hardy
  • #306
You have most amazing toys !
old jim
Likes Averagesupernova and OmCheeto
  • #307
old jim
Thanks. And they're beautiful, IMO.
Likes OmCheeto and jim hardy
  • #308
If you pull a vacuum with an old pump, will it produce a new vacuum or an old vacuum.
Likes dlgoff, NTL2009 and davenn
  • #309
Will there be any dark matter inside the old vacuum? :-)
Likes dlgoff
  • #310
I thought it would look neat to add some navigation lights to the Narco navigation antenna installation.
https://en.wikipedia.org/wiki/Navigation_light said:
Aircraft navigation lights are placed in a way similar to that of marine vessels, with a red navigation light located on the left wingtip leading edge and a green light on the right wingtip leading edge.
left navigation light:
right navigation light:
Likes jim hardy, OmCheeto and jedishrfu
  • #311
Is that a VOR or RDF ? Does it find your local radio stations ?
  • #312
VOR 108.1 to 117.95 MHz and communications 118 to 135 MHz. The VOR station that it's pointed toward is the Butler, MO VORTAC station @115.90 MHz.
Likes jim hardy
  • #313
Ahh found ya. Butler looks like a good check.. Topeka's no challenge !
Likes dlgoff
  • #314
Back when I was testing the Narco Super Homer, I found the latitude and longitude of the antenna using Google Earth for Windows and the latitude and longitude of the Butler VOR station using AirNav.com. Then by plugging in these co-ordinates into this distance and bearing calculation site, the Butler VOR station is 116.6 km at a initial bearing of 139°58'30" from the antenna.
Likes jim hardy
  • #315
Here's some of my RF stuff:
I came across this Kris 23+ CB Transceiver a year or so ago. It's in pristine condition and was in it's original box. I haven't found the exact time these were manufactured, but they were made in Japan. Probably in the late 1960s or early 1970s. Definitely beautiful; condition and all.
Now this Hammarlund CB-23 is what I used back in the 1960s. They were advertised in the June 1963 edition of Popular Electronics. Very hard to find now days.
Here's a transmitter for the 20, 40, and 80 meter Ham bands. It will require lots of work should I ever get to it.
Likes davenn, jedishrfu and jim hardy
  • Electrical Engineering
  • Electromagnetism
  • Electromagnetism
  • General Discussion
  • Art, Music, History, and Linguistics
