Bell's Paradox Question
  • Thread starter schaefera
  • Tags
    Paradox
In summary: You see, in your version the fact that the rope starts at D and is suddenly moving (making its length less than D) is affected by the fact that the ships remain distance D apart. But if the ships were accelerating, then their distance would also be decreasing (since their speed is increasing), and so the rope's length would be increasing even as the string's length decreases.
  • #141
Eli Botkin said:
Ghwellsjr:
Yes, bodies can be deformed, stretched, compressed, etc by forces. But that’s irrelevant here. This rigid body was accelerated by forces that were distributed and applied uniformly at every point of the body so as to get all points to accelerate in an equivalent manner. Clearly this is an idealism, not a realism.
If you accelerate a rigid body identically at more than one point along the direction of acceleration, then its length will change. If it is truly rigid, then it will break. Otherwise it will be stretched.
Eli Botkin said:
The outcome here is that regardless of how complicated the acceleration and deceleration history might be, the change in proper length depends solely on the final velocity change. This is a relativistic effect independent of the acceleration history and the force levels applied.
If you accelerate a rigid body at only one point, then it will end up with the same Proper Length no matter what speed it ends up at.
  • #142
DaleSpan:
In answer to 140:
I find no serious fault with your A,B,C
What I find unsettling is using the string's proper length in the co-moving frame when that length applies only to the ground frame. Note that the ships' proper separation changes by the SR transformation equations in either ship's co-moving frame (which is a momentary rest frame). Why is not the string length subject to that transformation?
I guess its your rejection of my view on proper length that I expounded recently ;-)
  • #143
ghwellsjr:
1) Sounds like you've settled the Bell Paradox issue: The string will break because it is rigid and is being accelerated at more than one point identically. Thank you.
2) Question: If you accelerate a body at one point,then do you not leave the other points behind? ;-)
  • #144
Eli Botkin said:
ghwellsjr:
You're welcome.
If it is a rigid body and you don't accelerate it beyond its ability to endure the stress, then the points behind will get dragged along and the points ahead will get pushed along until the acceleration ends and the body assumes the same shape and size at its new velocity (relative to its velocity prior to acceleration) as it had before.
  • #145
DaleSpam said:
So again, what is wrong with assuming a stiff string in the Bell's spaceship scenario? Do you object because you think the assumption is non-standard or because you think it is wrong? Please answer these questions directly instead of with an evasion.
A question has occurred to me:
If we assume a realistic rod connecting the ships so there is some degree of flex without breaking. The ships are spaced prior to acceleration such that there is a small degree of arc,
Say a drop of 5 cm. in the middle
In the launch frame, after an initial extremely short period as the momentum propagates through the rod, there should be no decrease in the deviation of the middle of the rod until eventually enough velocity is achieved to cause measurable contraction.
But in a frame moving in the same direction as the acceleration, the lead ship begins accelerating/moving first.
This would seem to indicate that the slack in the rod must instantly diminish to some extent. In a frame with a high velocity and therefore a greater interval between initiation of the front and rear ships, this seems like it would be significant.
Of course any changes in measurement of the difference in deviation would be transverse to motion, so the relative velocities would not affect this measurement in any frame.
Besides an actual coordinate displacement of the front ship relative to the rear , there would also be the resulting velocity away from the rear ship which would immediately continue taking up the slack and reducing the arc deviation from straight.
Without setting numbers, it still seems safe to say that a very small reduction of distance in the launch frame from the separation that would draw the rod taut would result in the small degree of sag I am talking about.
So it seems reasonable to suppose that a very small increase in the coordinate separation would then remove the deviation and render the rod straight between the ships.
Any thoughts??
  • #146
A note to all the Bell Paradox contributors with whom I’ve interacted.
I’ve enjoyed the time spent but it is now at a point where everyone is just *sticking to their guns*.
There is only repetition of positions held, both on your parts and on mine. I think none of us has the full answer to this riddle, though some may think they do; but it’s good that we keep on trying. I’ll chime in on other issues if I think I can make a useful contribution. My thanks to all.
Eli Botkin
  • #147
Any thoughts??
Nobody is ever going to carry out this experiment with actual spaceships and a connecting rod or string. You seem to think that a more complicated experiment would provide a more convincing demonstration. What's wrong with a simple string?
  • #148
Eli Botkin said:
ghwellsjr:
ghwellsjr said:
You're welcome.
Eli Botkin
Are you saying you weren't sincere in your thanks to me?
If you think that none of us has the full answer to this riddle, then you are admitting that you don't think you have the full answer. But don't extrapolate your own confusion on to the rest of us.
And it's not a riddle or a paradox. It's a simple problem with a simple answer. It's a shame you have given up learning and understanding.
  • #149
Eli Botkin
You said you would take a closer look at post #121 https://www.physicsforums.com/showpost.php?p=4041097&postcount=121 so it seems a shame you appear to be bowing out without keeping your promise. If you take a closer look at scenario 3 in that post it should make it crystal clear to you that the string stretches and eventually breaks in Bel's rocket paradox.
If you are still not convincd, then if you stick around a little while, I will post another scenario (4) which should make it even clearer.
Or is it just that you have already realized the string must break and just do not know how to gracefully accept your position was wrong?
  • #150
Eli Botkin said:
yuiop:
I appreciate your replies and will review them with care. A quick read, however, indicates an incorrect statement that appears often in many of this thread’s replies, leading to erroneous conclusions.
That statement is:
“Natural length contraction of the pole as the rockets accelerate…”
This is a misinterpretation of the often stated SR edict that “Moving bodies contract their length”.
I deleted that statement to avoid introducing a distraction, but it appears that you were replyiing to an old version of the post perhaps from an email notification. Anyway, it appears I was too late and you did allow the statement to distract you from the main points of post #121. :frown:
Bell introduced his rocket paradox to make an important point about the nature of length contraction and many so called experts at the time did not really understand length contraction and so came to wrong conclusion (similar to you) that the string does not break. If you take a different approach and accept that the string breaks (as most experts today would agree) then you work backwards and figure out why that must be the case and learn about the true nature of length contraction. In your earlier lecture to me on length contraction you said:
Eli Botkin said:
The two rod endpoints of course have worldlines. When T<0 in A (rod at rest in A) those worldlines are vertical and parallel, separated by distance L. When T>0 in A (rod moving in A) the worldlines are still parallel, but now sloped to the right. Their separation, at any value of T>0, in the x direction is still L. The now moving rod’s length as measured in frame A has not contracted from the length measured before motion in frame A.
... Can we measure the length of the moving rod in frame A? Yes, by sending and timing a light signal which is then reflected from both rod ends to the observer and applying a simple computation. Whether moving in A or not, the measurement by the A observer will yield the same length L.
Clearly you do not understand length contraction or spacetime diagrams. If the length of the rod is L when at rest in A, then when the rod is moving in A and the worldlines of the rod slope to the right, the length of the rod is not still L as measured by A. Maybe you do understand that measurements in A are made using clocks and rulers at rest in A's inertial reference frame?
  • #151
Any thoughts??
Hi Austin. I like the basic premise of your scenario and would like to present my slightly exaggerated version with a small twist that should hopefully make the physical nature of length contraction startling clear.I particularly like that in your variation the length contraction is clearly visible as a change in shape, rather than an invisible change in tension of a straight string.
Initially the two rockets on the ground are 1km apart and joined with a loose chain that is 2km long. Clearly there is very visible sag in the chain. When the rockets take off to the right and accelerate they maintain a separation of 1km as measured in the ground based reference frame.
Prediction: As the rockets accelerate the chain gradually tightens up until at 0.866c relative to the ground the chain lies in straight line between the two rockets. At some velocity greater than 0.866c relative to the ground, the chain will snap as long as the rockets can maintain the acceleration profile and as long as the chain is not infinitely strong.
Twist: To an observer going to the left the rear rocket appears to take off first and the two rockets appear to be getting closer together and yet this observer still sees the connecting chain getting straighter, just like all the other observers. The only explanation is that the chain is length contracting faster than the rockets are approaching each other in this frame. From this view point, length contraction is a physical phenomena. This is the part that I think Eli has difficulty accepting.
  • #152
Of course any changes in measurement of the difference in deviation would be transverse to motion, so the relative velocities would not affect this measurement in any frame [..]
While I like yuiop's post, he didn't really discuss your question. If I understand you correctly, in the launch pad frame we expect to observe that at first the rod is still sagging a bit, while in a frame that is moving fast along X we expect to observe that the front rocket will pull the rod straight as the rear rocket is not yet moving, which would be a contradiction.
I guess that this is where the dynamics seriously kick in and have to be examined (calculated). From both perspectives the front rocket pulls on the rod; and as long as the rod molecules are accelerating the rod will be under push&pull tension so that it is partly stretched and partly compressed. And necessarily the rear rocket takes off before the tension wave of the front rocket reaches it.
Thus, the idea that the slack in the rod must "instantly diminish" as viewed from the moving frame is certainly wrong, and I'm not so sure that at first nothing happens to the slack in the launch pad frame. So far my first 2cts. :tongue2:
  • #153
Eli Botkin said:
And no, I’m not, as A.T. suspects, considering an elastic string.
If you talk about proper length of the string changing over time, then you are talking about an elastic string.
Eli Botkin said:
The rigid body’s “proper” length can be altered by intermediate accelerations.
Then it is not a rigid body. A rigid body breaks, if you try to change it's proper length.
  • #154
Eli Botkin said:
DaleSpan:
In answer to 140:
OK, then since you admit that my proof was a valid conclusion from my assumptions, and since you now understand and accept my assumptions, then you must logically agree that it can be proven using SR that the string breaks.
The strings length is subject to the same relativistic effects as everything else. I will write some more details, but it will have to be later. Perhaps I can help you feel less unsettled.
  • #155
yuiop:
I know I said goodbye so very recently but your reply 150 just drew me back for this reply. I don’t know how you draw your Minkowski diagram so I’ll try to explain mine to you.
Draw the orthogonal axes (vertical T and horizontal X} to represent inertial frame A. Draw the worldlines of a rod’s endpoints in the region T < 0. Say the rod has length L and is at rest in frame A, then the two worldliness are vertical, say the left endpoint at X= 0, the right at X = L.
At T = 0 (in frame A) the rod is impulsively accelerated to a velocity V (relative to frame A) toward the right. Therefore both endpoint worldlines in the region T > 0 will slant toward the right at an angle = arctan(V/c) with respect to the T-axis.. Now note that in frame A the spatial separation between endpoints at any time T > 0 is still L, EVEN THOUGH THE ROD IS IN MOTION RELATIVE TO FRAME A.
Now draw the axes for an inertial frame B which will be the rest frame for the rod when T > 0. Call those axes (t, y). Of course these axes will not be orthogonal on this Minkowski diagram. The t-axis, drawn at the same clockwise angle as the worldlines will be parallel to the slanted worldlines, The y-axis is drawn at that same angle but counter-clockwise from the X-axis.
The time scale on the t-axis and the distance scale on the y-axis are set by the intersection of the t-axis with the family of hyperbolas T^2 – X^2 = a^2, and the intersection of the y-axis with the family of hyperbolas X^2 – T^2 = a^2.
I’ve selected the two sets of axes so that the two origins coincide.
In frame B, which is the rod’s new rest frame the separation between endpoints at any time t > 0, is measured along the y-axis. And if you do the math for this diagram you will discover that the rod’s length, as measured in this new rest frame B, has a length > L, showing that THE ROD HAS A DIFFERENT "PROPER" LENGTH AFTER THIS ACCELERATION.
Hopefully this explanation will help you and others who believe that the “proper” length of a rigid rod is universally fixed forever regardless of its acceleration history.
I know I had said that I would review your posts but our fundamental difference in viewing SR makes that a mute issue. Thanks again for participating.
  • #156
You still seem to think that accelerating a 'rigid' rod so as to preserve its length in its original frame can be done without destroying it.
  • #157
Doc Al:
Do we not "preserve" the separation between ships in its original frame though the ships have the same acceleration history in that frame? If you believe it is otherwise for the rod, even for mild accelerations, then it is not due to SR transformation between frames.
Rather you are positing other physical happenings to the rod. I have no problem with that since I don't know what you have in mind that is causing the destruction.
  • #158
Eli Botkin said:
Doc Al:
Yes, of course!
You seem to think that accelerating the rod in your destructive manner is simply equivalent to doing a Lorentz transform between inertial frames. Far from it!
Absolutely! This is not just viewing things from another frame--it is ripping the rod apart!
Whatever mechanism you used to accelerate the rod so as to preserve its length in the original frame is what is causing the destruction.
  • #159
If it was a rigid rod then it is broken, and doesn't have a proper length any more.
Isn't that the definition of "rigid"? How do you define "rigid", if not by constant proper length?
  • #160
To All:
It may be too easy to lose track of SR’s message. That message is that reality exists only in the worldlines that are engraved on the spacetime manifold. Any observer’s measurement of multi-worldline relations (such as time intervals or spatial separations, or even what we’ve chosen to call proper length) requires the observer to lay down a coordinate frame on the manifold.
In a real sense that is an arbitrary choice by the observer, except that we’ve choosen to follow SR rules in laying down frames because we are convinced that the SR postulates encompass reality. By laying down a coordinate frame the observer is just assigning an address to each worldline event. How those addresses change between observers follows the SR rules. The addresses we assign are not universal truths, so the computed time-intervals, distances and even proper lengths, cannot be.
  • #161
Doc Al:
You say "Whatever mechanism you used to accelerate the rod so as to preserve its length in the original frame is what is causing the destruction."
Is this so by your pronouncement? Or is there some physics proof you can share with us?
  • #162
Eli Botkin said:
[..] I don't know what you have in mind that is causing the destruction.
Well I think, just like Bell, that it's in principle quite simple, especially* if we limit ourselves to the perspective of the launch pad frame: "the [contraction] hypothesis of H.A. Lorentz and G.F. Fitzgerald appears [..] as a necessary consequence of the theory" -Einstein 1907.
According to that hypothesis, moving objects will have an equilibrium length that is reduced by the factor γ because the EM fields that hold the matter together contract along that direction.
* from the perspective of other frames, non-synchronous departure plays a role as well but while complicating the explanation, this doesn't alter the physical interpretation of Lorentz contraction
  • #163
Eli Botkin said:
Doc Al:
You just proved it yourself, by showing that the proper length of the string would have to increase to preserve its length in the original frame. For a rigid string that means breakage.
  • #164
Simple as that.
  • #165
Eli Botkin said:
It may be too easy to lose track of SR’s message: ... The addresses we assign are not universal truths, so the computed time-intervals, distances and even proper lengths, cannot be.
If by "universal truths" you mean frame invariant, then you are wrong. Proper lengths, just like proper time intervals and proper accelerations are frame invariant. What you call "SR’s message" is the common misinterpretation of SR, that everything is relative (frame dependent). It's not. And Einstein originally called SR the "Theory of Invariants", to put emphasis on those "proper" quantities, that are frame invariant.
  • #166
A.T.:
The frame-invariant in SR is dS^2 = [T^2 - (X^2 + Y^2 + Z^2)]. All else in SR must follow from that.
  • #167
A.T. & Doc Al:
"You just proved it yourself,..." & "Simple as that."
The physics of the rigid body hasn't changed because the observer has changed. They just have different views of what they observe ;-)
  • #168
Wrong. The number of my legs is frame-invariant too, but that doesn't follow from the above.
Exactly. That's why proper length is frame-invariant. It doesn't change because the observer has changed.
But if that proper length would have to increase over time (as you have shown), then a rigid string would break for every observer.
Try to keep "frame invariant" and "time invariant" apart.
  • #169
Eli Botkin said:
Doc Al:
The two "separations" are different.
The separation between the spaceships is being preserved in the ground observer's frame, which is not the rest frame of either ship. In the ship frame (frames while they're accelerating, frame after the acceleration has ended and they've both stabilized at the same speed) that separation increases.
The rod's length is preserved in the rest frame of the rod, which is moving with the spaceships, at least until it breaks. So the length of the rod is constant in the frame in which the spaceships are separating.
I'll get the space-time diagram I promised you, the one showing the whole thing from the point of view of the left-moving observer, cleaned up and posted in the next day or so. It is seriously illuminating not just because it's the left-moving observer you asked for, but because both ground observer an ship is moving.
  • #170
A.T.:
I forgot to tell you that your legs are frame-invariant because all events in one frame are also there in other frames, and I would guess that your legs are events ;-)
  • #171
And the proper-length of my legs is frame-invariant, because it's per definition the length that I measure in my rest frame. Just like my proper-time is frame-invariant, because it's per definition the time that I measure in my frame.
  • #172
Eli Botkin said:
A.T.:
Your guess would be wrong. An event is a single point, defined by four coordinate (x, y, z, and t) in the most obvious Minkowski coordinates. A.T.s legs are a collection of multiple events, and statements about their size, shape, and length are in fact statements about relationships between these events. For example, the measured length is the spatial distance between two events, one at the heel and one the hip - choosing two events that have the same value of t in the reference frame in which the measurement is made, of course.
Some of these relationships are frame-invariant, meaning that they hold in all frames. For example, the quantity [tex]\int_P \sqrt{g_{\mu \nu} dx^{\mu} dx^{\nu}}[/tex] integrated along a straight line between the heel and hip events will be the same in all frames, even though the coordinates may be wildly different. (It will also be equal to the measured length of the leg in a frame in which AT and his legs are at rest).
Other relationships, such as the measured length of AT's leg, are not frame-invariant. You'll get different answers in frames moving at different velocities relative to AT. However, these lengths can be calculated from the known velocity and the frame-invariant quantity above (which is, BTW, the infamous "proper length" of another fork in this thread), using the well-known formula for length contraction.
  • #173
Hi Eli,
Let me explain some of the core concepts of relativity and how they relate to length.
First, even more basic than relativity is the form of the laws of physics. The laws of physics are expressed in terms of differential equations. A differential equation explains how something changes over space and time. In order to use them you also need to provide a set of initial conditions, or boundary conditions. Once you have that set of boundary conditions you can use the differential equations of the laws of physics to predict how the situation changes over time and space.
The principle of relativity means that the laws of physics are the same in all frames. That means, if there is some specific experimental measurement we perform and we use two different frames to predict the measurement then both frames must use the same laws of physics and get the same number. Furthermore, since both frames are describing the same experiment there must be some well defined equation relating the boundary conditions in one frame to those in another frame. That mathematical relationship is called a coordinate transform.
The principle of relativity can then be taken to mean that the form of the laws of physics is not changed under the transformations that relate the boundary conditions in one frame to those in another frame.
So far so good? Any questions so far?
  • #174
So, now for a few definitions:
Clocks are experimental measuring devices which measure a quantity called proper time. Because proper time is the measured outcome of a physical device it must be frame invariant.
This is contrasted with coordinate time (often just called time). Coordinate time cannot be directly measured, but instead requires a frame-dependent convention for which events are simultaneous. However, in a given frame changes in coordinate time are equal to changes in proper time for clocks which are at rest.
This nomenclature is pretty common, a directly measurable frame invariant quantity designated as proper and a related frame variant quantity designated as coordinate or undesignated. Usually the two are equal in the rest frame of the measuring device.
Another example is acceleration. An accelerometer is an experimental device which measures a quantity called proper acceleration. It is equal to the coordinate acceleration in a reference frame where it is momentarily at rest.
Finally, proper length is the frame invariant quantity measured by a rod. It is equal to the coordinate length in the frame where the rod is at rest.
Is that clear?
  • #175
Eli Botkin said:
... Now note that in frame A the spatial separation between endpoints at any time T > 0 is still L, EVEN THOUGH THE ROD IS IN MOTION RELATIVE TO FRAME A.
You seem to think that the only way to increase the stress on a rod is to increase the spatial separation of its endpoints. Here is a counterexample. Imagine you have metal rod that is 1m long at room temperature. It is heated to 1000 degrees C so that it expands by about 1cm and then the ends are clamped so that they cannot move. It is also clamped in such a way that while it is still hot, the metal rod is unstressed. When the metal is cooled back to room temperature, it will try to regain its unstressed length (1m) but since it cannot, it becomes stressed and may even break. This destructive stress comes about with no change in the spatial separation of the rod endpoints.
Eli Botkin said:
... And if you do the math for this diagram you will discover that the rod’s length, as measured in this new rest frame B, has a length > L, showing that THE ROD HAS A DIFFERENT "PROPER" LENGTH AFTER THIS ACCELERATION.
This is your fundamental misunderstanding. The only way you can increase the proper length of a rod is by applying stress (forces) to the rod. For example I can take an elastic band in my fingers and change its proper length, at will, by simply stretching the elastic band. The important point is that the change in the proper length is accompanied by a change in the tension of the elastic band. If an object remains unstressed then its proper length cannot change. I notice you almost never mention words like "unstressed" or "tension" in your posts, so perhaps you do not realize those physical aspects involving forces are important?
Eli Botkin said:
... Hopefully this explanation will help you and others who believe that the “proper” length of a rigid rod is universally fixed forever regardless of its acceleration history..
I will state my belief as "The proper length of a rod that remains unstressed (or under constant tension) does not change, regardless of its acceleration history and regardless of its velocity relative to the observer". On the other hand, the coordinate length (the length measured by an observer moving relative to the rod) of the rod under constant tension, does depend on the velocity of the rod relative to the observer and under those conditions the coordinate separation between the endpoints becomes smaller with increasing relative velocity. If the endpoints are not getting closer together (as measured in the initial frame that sees the rod as moving), then the tension on the rod must be increasing and eventually break, as does the string in Bells rocket paradox.
