Below zero Kalvin
  • Thread starter jaredmt
jaredmt
121
is this possible anywhere?
i know 0 kalvin is the lowest temperature possible that we've been able to attain. but is it possible that in outerspace where there is no heat from sun, that it gets below zero kalvin?
im just curious. I am not sure wether this was "proven" to be the lowest possible temp or just the lowest temp we've been able to get. because i do know that no matter how hard you try to take heat out of something, more heat will just keep going back into it at the same time
Answers and Replies
Mapes
According to current understanding, no temperature below 0 K exists. Also, it is not possible from a practical perspective to cool an object to 0 K (the process would take an infinite amount of time). The lowest humans have achieved is less than one billionth of a Kelvin, far colder than interstellar space, which is approximately 2.7 K.
Poop-Loops
721
Yes, we've never been able to get to 0K. Space is at about 2.7K like Mapes says because of the Cosmic Background Radiation.
The reason we can't get to 0K is because of statistical mechanics, basically.
http://en.wikipedia.org/wiki/0K
lightarrow
1,939
50
Yes, it's possible, in a Laser system, for example.
Temperature can be defined as the partial derivative of energy with respect to entropy; in a system like a Laser, there is "population inversion" so entropy *decreases* instead of increase, when energy increases, so the absolute temperature is negative.
Mapes
As Norman Ramsey has pointed out, objects with negative temperature are not colder than absolute zero, but instead hotter than anything else. Heat energy will always flow from a inversion state to a state that is closer to equilibrium; this is the characteristic of a high temperature, not a low temperature.
Andy Resnick
Education Advisor
Insights Author
7,755
2,684
As lightarrow points out, the statistical-mechanical origin of 'temperature' can lead to counterintuitive results- for example, a population inversion in a two-state system corresponds to negative temperatures.
0 K should be considered a thermodynamic limit.
'0 K' is not acheivable due to the laws of thermodynamics, and it is also not true that 'all motion ceases at 0 K' due to the zero-point energy.
jaredmt
121
ok that is confusing that -k is actually hotter than +k. there are actually mechanical tests where they created a negative temperature? and it was hotter? that's strange
mgb_phys
7,889
Probably better to think of it as a mis-use of the concept of temperature.
There are areas of solid state physics where you treat an electron as having negative mass - the maths works and you get the right answer - but it's not necessarily 'real'.
jaredmt
121
o. so basically we just arent technologically advanced enough to get the right formula to achieve the real -k (if it exists)
Mapes
How did you conclude that from the responses? It's not a technological barrier.
mgb_phys
7,889
No I mean that negative temperature in a laser inversion isn't real it's just a convenient mathematical trick.
It's like being overdrawn at the bank, you don't really own 10 negative dollars - it's just easier to do the sums that way.
Suggested for: Below zero Kalvin
  • Last Post
  • Last Post
