Bernouilli Equation Difficulty
  • Thread starter CollectiveRocker
  • Tags
    Difficulty
In summary, the conversation discusses a large tank of water with a hose connected and compressed air sealed at the top. When the water height is 3.5 m, the absolute pressure of the compressed air is 4.20 * 10^5 Pa. The velocity is also given for different water heights and the question is raised about how to solve for when the velocity is 0. It is mentioned that rearranging the Bernoulli equation is necessary and that the terms (1/2)pv1^2 and (1/2)pv2^2 cancel when the velocity is 0. The equation for solving for the water height when the velocity is 0 is also provided.
CollectiveRocker
137
A large tank of water has a hose connected to it. The tank is sealed at the top and has compressed air between the water surface and the top. When the water height h has the value 3.5 m , the absolute pressure p of the compressed air is 4.20 * 10^5 Pa. Assume that the air above the water expands at cosntant temperature, and take the atmospheric pressure to be 1.0 * 10^5 Pa. When the h=3.5 m, velocity = 26.2 m/s. When h=3.0, v=16.1m/s. When h=2.0 m, v = 5.44 m/s. How do I solve for when the velocity equals 0? I realize that I have to rearrange the Bernouilli Equation. Do [(1/2)pv1^2] and [(1/2)pv2^2] cancel when this happens?
Yes, when the velocity is 0, the terms [(1/2)pv1^2] and [(1/2)pv2^2] cancel. You can rearrange the Bernoulli equation as follows:h2 - h1 = (1/2)*(p1/ρg - p2/ρg)*(v1^2 - v2^2)where h1 and h2 are the initial and final water heights, respectively, p1 and p2 are the pressures of the compressed air in the tank at the initial and final heights, respectively, ρ is the density of the water, g is the acceleration due to gravity, and v1 and v2 are the velocities at the initial and final heights, respectively. In your case, set v1 = 26.2 m/s and v2 = 0 m/s. Solve for h2. This will give you the water height when the velocity is 0.
To solve for when the velocity equals 0, you can rearrange the Bernoulli equation to solve for v, which is the velocity. When the velocity equals 0, the equation will look like this:
v = √(2gh + (p1-p2)/ρ)
Since v equals 0, we can remove it from the equation, leaving us with:
0 = √(2gh + (p1-p2)/ρ)
To solve for h, we can square both sides of the equation:
0 = 2gh + (p1-p2)/ρ
Next, we can isolate h on one side of the equation by subtracting (p1-p2)/ρ from both sides:
- (p1-p2)/ρ = 2gh
And finally, we can solve for h by dividing both sides by 2g:
h = -(p1-p2)/(2ρg)
So when the velocity equals 0, the water height will be equal to -(p1-p2)/(2ρg).
To answer your question about the terms [(1/2)pv1^2] and [(1/2)pv2^2], they do not cancel out when the velocity equals 0. These terms represent the kinetic energy of the water at two different points in the tank, and they will be equal to each other when the velocity is 0, but they will not cancel out.
I hope this helps you solve for when the velocity equals 0 in this problem. Keep in mind that the Bernoulli equation is only applicable in certain situations, so make sure to check if it is appropriate to use in your specific problem.
What is the Bernouilli Equation Difficulty?
The Bernouilli Equation Difficulty is a concept in fluid dynamics that refers to the complexity and level of mathematical understanding required to solve the Bernouilli equation, which relates the pressure, velocity, and elevation of a fluid in motion.
Why is the Bernouilli Equation Difficulty important?
The Bernouilli Equation Difficulty is important because it allows scientists and engineers to calculate the behavior of fluids in motion, which is essential for understanding a wide range of phenomena such as aircraft lift, blood flow, and water flow in pipes.
What factors affect the Bernouilli Equation Difficulty?
The Bernouilli Equation Difficulty can be affected by several factors, including the type of fluid, the complexity of the flow, and the presence of external forces such as gravity or friction. Additionally, the use of real-world data and assumptions can also impact the difficulty of the equation.
How can one solve the Bernouilli Equation Difficulty?
The Bernouilli Equation Difficulty can be solved using various mathematical techniques, such as integration, differentiation, and substitution. Additionally, the use of computer software and numerical methods can also help solve the equation accurately and efficiently.
What are some common applications of the Bernouilli Equation Difficulty?
The Bernouilli Equation Difficulty has numerous applications in various fields, including aerodynamics, hydrodynamics, and biomechanics. It is used to design efficient aircraft wings, predict the flow of water in pipes, and understand the blood flow in the human body, among others.
9K
