Solving Bernoulli Equation: Confirm Results and Identify Error
In summary, the Bernoulli equation can be solved by letting Z = y1 - 2. y' is found to be = 25x4/(5c1 - x5)2.
Saladsamurai
3,020
I have solved the following Bernoulli equation by letting Z = y1 - 2:
xy' - 2y = x3y2. I obtained the solution
y = 5/(5c1 - x5)
which Wolfram Alpha has confirmed.
From this result, I have obtained y' to be
y' = 25x4/(5c1 - x5)2
The problem is when I go to check the solution by plugging into DE:
x*25x4/(5c1 - x5)2 - 2*5/(5c1 - x5)
[tex] = \frac{25x^4}{(5c_1 - x^5)^2} - \frac{10}{5c_1 - x^5} = \frac{25x^4}{(5c_1 - x^5)^2} - \frac{10*(5c_1 - x^5)}{(5c_1 - x^5)^2}[/tex]
which will never equal the right hand side of the original equation:
[tex]x^3y^2 = x^3\frac{25}{(5c_1 - x^5)^2}[/tex]Anyone seeing where I am messing this up?
thanks.
Hello fellow engineer ,
First of all your y(x) and wolframs y(x) are not the same function.
You are missing an [tex] x^{2}[/tex] term.
Ahhh...yes. Thanks! So let's try this again...
The solution to xy' - 2y = x3y2 is given by
[tex]y(x) = \frac{5x^2}{5c - x^5} = 5x^2(5c - x^5)^{-1}[/tex]
[tex]\Rightarrow y'(x) = (5x^2)\cdot[(-1)(5c - x^5)^{-2}(-5x^4)] + ((5c - x^5)^{-1})\cdot[10x][/tex]
[tex]\Rightarrow y'(x) = \frac{25x^6}{(5c-x^5)^2}+\frac{10x}{5c-x^5}[/tex]
[tex]\Rightarrow y'(x) = \frac{25x^6+(5c - x^5)(10x)}{(5c - x^5)^2}[/tex]
Plugging the result back into original DE we have
[tex]\frac{25x^7+(5c - x^5)(10x^2)}{(5c - x^5)^2} - 2*\frac{5x^2}{5c - x^5}=
\frac{25x^7+(5c - x^5)(10x^2)}{(5c - x^5)^2} -\frac{(5c - x^5)(10x^2)}{(5c - x^5)^2} = \frac{25x^7}{(5c - x^5)^2} = A
[/tex]
From the right side of original DE we know that
[tex]A' = x^3y^2 = \frac{(x^3)(25*x^4)}{(5c - x^5)^2} =\frac{25x^7}{(5c - x^5)^2} [/tex]
Thus, A = A' and we must have the solution.
Thanks for catching that error! :smile:
1. What is the Bernoulli equation and how is it used in science?
The Bernoulli equation is a fundamental principle in fluid dynamics that relates the pressure, velocity, and height of a fluid. It is commonly used in various areas of science, such as aerodynamics, hydraulics, and meteorology, to analyze the flow of fluids and predict their behavior.
2. How do you solve the Bernoulli equation?
The Bernoulli equation can be solved by equating the total energy at two different points along a streamline. This involves considering the kinetic energy, potential energy, and pressure energy of the fluid at each point and setting them equal to each other.
3. What are some common errors when solving the Bernoulli equation?
One common error when solving the Bernoulli equation is neglecting certain terms, such as the potential energy term or the effects of friction. Another error can be using incorrect units or not properly accounting for changes in density.
4. How can you confirm the results of solving the Bernoulli equation?
The results of solving the Bernoulli equation can be confirmed by performing experiments and comparing the predicted values to the actual values measured. Additionally, the results can also be checked using other theoretical methods or equations.
5. What are some real-world applications of the Bernoulli equation?
The Bernoulli equation has many practical applications, including designing aircraft wings, calculating water flow in pipes and channels, and predicting weather patterns. It is also used in medical devices, such as ventilators and blood flow meters, and in sports equipment, such as golf balls and tennis balls.
