Best IDEs for Java Dev Work?
  • Java
  • Thread starter WWGD
WWGD
7,749
Hi All,
Teaching myself Java programming from 0. I used some online forums. Now I would like to work, programming on my own PC, i.e., not just as a client . What are good IDEs for Database Dev work? I have been recommended Atom .
Answers and Replies
8,025
Atom is mostly an editor with a lot of third party plugins that support other languages.
We use Netbeans at work. It’s a one stop shop with all essential java development tools. There are also third party plugins although offhand I don’t know of a sql plugin for database devs.
Others to look at are Eclipse, IBMs variant ie Websphere IDE based on Eclipse will have support from DB2 and sql. MS Visual Studio should have support for their product too.
Lastly, there’s IntelliJ but I’ve not used it but it too should have some support for sql
8,025
The H2Databse product, as an example, has a web based console where you can vie table contents and run queries.
This is good if you’re using java to develop a database application using jdbc and sql to do updates then use the console to check what got stored.
Borg
3,306
What do you want to accomplish with your IDE with respect to the database? Are you looking to create and modify tables with it, display schemas, etc.? I have been using IntelliJ for over a decade. I used to use its DB tools with good results when I was working with relational databases. However, I've been working with mostly MongoDB for the last 5 years and prefer to use RoboMongo or scripts when I need to work with the data.
Likes WWGD and jedishrfu
Kyle Gonterwitz
+1 for eclipse, there used to be a TOAD plugin that was really good for oracle database development, but I have not seen that plugin lately, I think it reached it's EOL. Still, Eclipse has some SQL developer tools and if you are learning Java then it's also good for that purpose too.
Dr Transport
Insights Author
723
I used Textpad years ago for java it worked pretty well from what I remember.
8,025
A key feature of the best IDEs is giving you a selection of methods when you type a period after an instance or a Class.
As an example, typing Math. in java will give you a list of Math supported constants E and PI and a list of static methods for trig, log, power, root, ... basic operations.
It speeds development and often gives you a brief description of the arguments to the method you selected.
Netbeans, Eclipse and IntelliJ all do this, some fancy syntax hilighting editors do not. Processing is one example where that feature is absent although I’m sure they’ll add it some day...
Likes WWGD and Borg
WWGD
7,749
Thanks; sorry if this is too vague, but just general application work.
Borg
3,306
If you're not using the database portion for much more than occasionally checking a few records in the database, then any IDE will suit your needs. All of the IDEs will work with database APIs like any other Java package using imported packages and/or plugins for that IDE.
In general, I mainly write unit tests and scripts to test that the data is being processed correctly by my code.
Likes jedishrfu and WWGD
Suggested for: Best IDEs for Java Dev Work?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
