Homework Help: Bicycle Problem
  1. Nov 29, 2006 #1
    A bicycle has 30cm radius tires with gear and pedal dimensions as shown. IF the maximum vertical force that a 70kg rider can exert is equal to his/her body weight, what is the horizontal force that can be exerted on the ground by the rear tire?
    http://img48.imageshack.us/img48/8492/28mn1.png [Broken]
    2. Relevant equations
    same as Spool question
    3. The attempt at a solution
    well first I got 686 N [70x9.8] but I have no idea what point to use as the pivot.
  3. Nov 29, 2006 #2
    berkeman
    Staff: Mentor
    Assume it's in equilibrium. Calculate the torque of the pedal at its radius to the crank axle. Then the reverse torque of the chain at the front sprocket has to be equal and opposite, right? Then calculate the resulting torque from the chain on the rear sprocket, and that has to be equal and opposite to the torque from the tire about the rear axle, right?
  4. Nov 29, 2006 #3
    So first i would go:
    (686)(0.18) is that just the torque of the crank axil, or is there more to do?
  5. Nov 29, 2006 #4
    berkeman
    Staff: Mentor
    First you would use units in all of your equations. And yes, so far so good. Now what force from the chain balances that torque?
  6. Nov 29, 2006 #5
    would that be 123.48N? but in the opposite direction
  7. Nov 30, 2006 #6
    berkeman
    Staff: Mentor
    Help me out here, son. Work out the full solution with units and annotations, and I'll check it. I honestly don't have enough time to work through each of six steps in a row checking your work all the way and trying to figure out how you calculated each intermediate step.
    Sorry to have to push back, but the PF is a valuable resource for us all, and you need to learn to use it efficiently. You can do it, I know you can. Work out the full problem using units, and post your full work with some description. I'll be happy to efficiently check your work. I bet you get right!
  8. Nov 30, 2006 #7
    K but just one thing, would you count the chain as one part, or would u put the torque in both sides of the chain, or duz it even matter?
  9. Nov 30, 2006 #8
    berkeman
    Staff: Mentor
    I think it duz matter. A chain is a linear force transfer device. It generally transfers a force to different diameter sprockets, as in this problem. The tension force out one side of it equals the tension force out the other side. That's how you get different torques -- by having different diameter sprockets connected by the same chain).
  10. Nov 30, 2006 #9
    K I learn best by seeing what some one else does. SO would it be easier if you posted your work and then I could simply see how you did it?
  11. Nov 30, 2006 #10
    OlderDan
    You seem to be missing the point. This is not a lecture session. This is a place for you to bring your work and get help when we see where you are going wrong.
  12. Nov 30, 2006 #11
    Yeab but, if I cannot progress further into the question, doesn't that mean you can help me out? Maybe I don'tunderstand your help very well because I cannot interprate english as well as I can interpret math and concepts. It is not a lecture because I already know what torque is and I get the basic principles of this question, I just need help putting 2 and 2 together.
  13. Nov 30, 2006 #12
    OlderDan
    Let's break it down. The pedal is not accelerating, so the chain is applying a torque opposite the torque from the vertical force from the foot. Calculate the force from the chain on the sprocket.
    The force from the chain is a tension in the top part of the chain. The bottom of the chain is slack. (or the differentnce in tension between the top and bottom of the chain provides the torque. It really does not matter how you look at it. Assume the bottom is slack) The tension in the top part of the chain applies a torque to the rear sprocket. Calculate this torque. (The chain is not accelerating, so the tension is uniform throughout the top.)
    The wheel is not accelerating. The horizontal force from the ground on the perimeter of the wheel is applying a torque opposite the torque from the chain. Calculate this force.
    By Newton's third law, the horizontal force the ground applies to the tire is equal and opposite to the horizontal force the tire applies to the ground. The problem is solved.
  14. Dec 1, 2006 #13
    Ok I appreciate you trying to help me, I see how frustrated you probably are. It makes more sense now that I realized the bottom part of the chain is slack (duh). K what I first did with my new found knowledge was: (686N)(18) = 12348 Nm. I then divided this by 12(the radius of the small gear) to get the tension which gave me 1029 N for the tension. Now i multiplied 1029N by 6(the radius of the pin region in the middle of the tire) which gives you the torque of that are(I hope). I divided this by 30(the tires radius) which should have given me the force of the tire pushing on the ground and vice versa. I hope this is right, though I wouldn't doubt it if it's not. Sorry, It's just Im learning on my own and it's hard to get help with things without a teacher.
  15. Dec 1, 2006 #14
    OlderDan
    I did not check all your numbers, but it sounds like you've got it. It's just a matter of equating torques as you work through the system from one end to the other.
  16. Dec 14, 2006 #15
    Hi. Thank you so much for posting this thread which I am so interested in!
    I this the right way to find the answer:
    earth's gravity*rider's mass*18m*(1/12)m = horizontal force*30m*(1/6)m
    (9.8ms2)(70kg)(18m) / 12m = horizontal force (30m) / 6m
    205N = horizontal force
  17. Dec 14, 2006 #16
    OlderDan
    Your last m on each side of the first equation belongs inside the parenteheses, and all of the m should be cm, but since all those m units divide out, you finished OK.
