Bicycling on the Moon
Danger
251
So you are as likely to lose your balance on the moon as on the earth, then. You won't fall as fast on the moon, but you will still fall.
But that slowness of falling gives one more time to counter the imbalance and prevent the fall.
It seems that some of the people here are confusing the fact that you are falling with the fact that you can prevent hurting yourself more easily.
DaveC426913
3,388
:grumpy::grumpy::grumpy:
You can prevent yourself from falling.
The OP's question is not about a static, unoccupied bike simply sitting on the ground waiting to fall over. The OP's question is about riding a bike, and whether you are less likely to fall over. One cannot "ride" a bike without acting to stay balanced on it.
Simply put, when riding a bike on the Moon, you are less likely to fall over than on the Earth because the act of staying riding is easier.
Then we agree. You still have to take action to maintain balance.
Don't get all mad, Dave. :)
  • #31
DaveC426913
3,388
You must have driven your parents crazy in your 'but why is the sky blue?' phase...
  • #32
Danger
251
Dave doesn't get mad; he gets logical. That's far more frightening. I can certainly understand his frustration in this instance. People are trying to counter his knowledge of physics with preconceived notions of how things work based upon terrestrial existence. That irritates me, as well.
  • #33
So you understand where I'm coming from now, do you?
  • #34
DaveC426913
3,388
Uh well, since you ask, I think you've been obtuse, missing the point. Now you seem to be pretending that you were agreeing with me all along.
  • #35
I'd be interested to know why you think this. PM me about it. I think the OP has been answered.
  • #36
Danger
251
It seems kind of obvious from an external perspective. You were arguing against Dave until you realized that you were losing, then turned around and claimed that you were agreeing with him. It might be a clever approach to winning arguments where you come from, but it's way too transparent to fly here.
  • #37
196
One thing that hasn't been mentioned is tyre grip on the Moon.
It works out that at 1/6 of Eath's gravity (which is what you have on the Moon) the rubber tyre grip goes down to 1/4 of what it would be here on Earth. (not 1/6, because the coefficient of friction goes up by a factor of about 1.43 for a 1/6 load)
So if a bike on Earth can corner at 1G (9.81m/s/s), on the moon the same bike has max cornering grip of only 1/4G.
So in that sense it would be harder to stay on it. - You'd have to corner a lot slower to keep the bike from falling away from underneath you anyway.
Oh, and braking. You wouldn't be able to stop as quickly for the same reason. Or accelerate - bikes accelerate pretty fast from a standstill here on Earth, so just getting going could be quite difficult - though I admit I've never tried this myself..
  • #38
Danger
251
But we'd be using Moon rubber; surely that's different... :uhh:
  • #39
4,662
It works out that at 1/6 of Eath's gravity (which is what you have on the Moon) the rubber tyre grip goes down to 1/4 of what it would be here on Earth. (not 1/6, because the coefficient of friction goes up by a factor of about 1.43 for a 1/6 load..
The coefficient of friction (COF) is a unitless ratio of the horizontal force to push (or pull) an object divided by its (vertical) weight (gravitational force mg) on the moon. Why does the COF change on the Moon?
Bob S
  • #40
196
The coef of friction for rubber goes up if the force pushing it down is lower.
i.e. It just happens that for rubber the coef of friction isn't at all constant, and rubber grips a little better with less weight on it. That's why race cars are usually built as light as regulations allow, to give them max grip.
Moving to the Moon makes things a bit weirder, because you're not reducing the mass of the vehicle, only it's weight is reduced. It's the weight (or normal reaction to the weight if you prefer) that gives the tyre it's grip. The mass is that which tries to keep the vehicle moving in a straight line. That has stayed the same as on Earth, but your friction is less.
I think I explained that a bit backwards, I probably should have put the 3rd paragraph first to explain why grip is lower on the moon in the first place. The fact the coef of friction changes a bit adds some extra info but isn't that important is it. As far as I know the info I've given is correct.
  • #41
DaveC426913
3,388
I don't really see how any good can come from that.
Related Threads on Bicycling on the Moon
  • Last Post
  • Last Post
  • Last Post
18K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
